In about three weeks, we are supposed to finalize our electrical planning on site. Unfortunately, our electrician is somewhat old-fashioned, which makes it difficult for me to collaboratively plan a future-proof electrical setup with him. Therefore, I am currently educating myself to ensure that the networking in our single-family home is fundamentally future-proof.
Basically, it’s about the LAN network... LAN wall outlets are relatively expensive, so proper planning is even more important.
About us:
- Mid to late 20s – couple without children. Planning for 2 children in the near future.
- Single-family house with a usable basement, 2 full floors, and fully equipped with concrete ceilings
- Utility room in the basement with air-to-water heat pump, ventilation system, photovoltaic system
- The router is planned to be located in the office on the ground floor
- The upper floor includes bathroom / bedroom / 2 children’s rooms
- No satellite dish or cable TV — we will use Internet TV exclusively!
Now, I am struggling to network our single-family home sensibly but as cost-effectively as possible.
I have the following questions:
1. Slightly off-topic: In the living room, I would like to have an in-wall conduit installed on the TV wall (the TV will be wall-mounted) so that no cables are visible. Is this sensible and affordable? I will get exact prices from my electrician if this makes sense at all. Would it also make sense to install power outlets at TV height? How do you plan the connections on your media wall reasonably? What should be considered?
Since we plan to use a Magenta TV box and thus IP-TV, a total of four LAN ports in the living room area would presumably be useful, right?
2. How many LAN outlets and especially where should LAN outlets be installed? Mainly: which cable? Is CAT6 sufficient?
→ Such a double LAN outlet certainly costs close to €200, so planning must be really sensible.
Is it really necessary to install 2 double LAN outlets in each children’s room? I always wonder: what is actually going to be plugged in there?
One port for the TV and one port for a multimedia device should be enough, right? So four connections would probably be overkill, correct?
The fact is: It will certainly take years or decades before our children actually use these outlets... Who knows what changes might happen by then? Therefore, could we not cost-effectively use empty conduits (empty pipes) instead?
Is it also possible to “branch off” from an existing double outlet afterward to add more ports for the room? What should be considered here? Or should we consider having an empty conduit prepared in another spot in the room so that a socket can be installed later?
3. How do you solve the “router problem”? Should the one router be placed in the office (ground floor) with LAN outlets in the existing bedrooms upstairs to ensure a stable LAN connection? Or is a router upstairs absolutely necessary?
4. How important are LAN outlets in the utility room? Should the router possibly even be located in the utility room? Because of the concrete ceiling between basement and ground floor, a second router would almost certainly be needed. How should this situation be handled with a basement?
5. What do you think about installing empty conduits for CAT cables in the kitchen / hallway etc. to enable later retrofitting? Is this relatively affordable in new builds?
I would appreciate any feedback so we can make the best possible plans 🙂
About us:
majuhenema schrieb:
..with the equipment in the utility room, I’m already well over the limit, or do they only need to connect to the 48-port switch and not to a 24-port patch panel? Yes, that’s exactly what I wrote. Did you read the text?
DamDumDob schrieb:
Only 16 cables are definitely planned, which is enough for that. The spare cables are neatly coiled behind the patch panel for now. Exactly. I also have about 32 installation cables plus the equipment in the utility room, so in total, around 40 connections. The 24-port patch panel has been sufficient for that so far.
majuhenema4 Jan 2022 14:20Mycraft schrieb:
Yes, that’s exactly what I wrote. Did you read the text?Exactly! 🙂 With my confirmation, I wanted to check if I understood it correctly, because I was wondering, “Why don’t the items from the technical room connect to the patch panel, but can go directly to the switch?”
Mycraft schrieb:
Exactly. I also have about 32 installation cables plus the items in the main distribution frame (MDF), so in total about 40 connections. The 24-port patch panel has been sufficient so far.Then I will leave our planning with 25 installation cables from #77 as is for the construction design.
Pumpernickel115 Jan 2022 11:04We discussed the topic of access points with the electrician. However, he did not consider it necessary since there will be network outlets everywhere where a Wi-Fi repeater could be connected. Therefore, we decided to exclude the access point solution.
Pumpernickel1 schrieb:
Could connect a Wi-Fi repeaterIf he really said repeater, he is basically not qualified to give advice on network topics.If you don’t care much about Wi-Fi, then just leave it as is. If it matters to you at least somewhat, do it properly with access points installed under the ceilings, with at least one per floor.
since there will be network outlets everywhere,They just aren’t located where you would ideally place an access point.
That's just how it is. The electrician is usually the absolute last point of contact when it comes to networking. I have no idea why everyone always trusts the electrician for that. Almost 10 out of 10 electricians in the private home construction sector have no real knowledge of networking beyond installing the outlets, yet they still constantly share their limited or incorrect knowledge with even less informed customers.
