ᐅ New Construction Lighting Design and Implementation
Created on: 7 Jun 2016 23:04
Momad
how did you approach lighting design and when exactly did you plan/implement it?
I still have the option to install Halox P housings with transformer tunnel (€60) for LED recessed spots. I’m not really convinced by spots (focused light + high costs), but what alternatives are there?
jansens
16 Mar 2018 18:00
I agree with your planner on this. If you choose white light, make sure the color temperature is consistent within the same room. If you want to change it dynamically via KNX, that’s fine. The most important thing is that all light sources are adjustable. At the moment, we have 2700 K in the living/dining area. It’s cozy and still sufficient as task lighting in the kitchen. Brightness also plays a big role.
11ant16 Mar 2018 18:36
I would say that light bulbs can be replaced, so this is not really a decision but merely a choice.
R.Hotzenplotz
16 Mar 2018 19:24
jansens schrieb:
I agree with your planner on this. If you choose white light, keep the same color temperature within one room. If you want to dynamically change it via KNX, that’s fine. The main thing is that all light sources are adjustable. We currently use 2700K in the living/dining area. It’s cozy and still sufficient as task lighting in the kitchen. Of course, it also depends a lot on brightness.
Isn’t that a contradiction?
If I have a light source with 2700K, how can I then dynamically adjust it?
Dynamic adjustment would only be possible with different fixtures that can each display various color temperatures, or am I mistaken?
Adjustable = replaceable light sources?
I would say light sources can be swapped, so it’s not really a fixed decision, just a choice
An expensive choice. I wouldn’t want to have to replace them after a short time just because I don’t like them. I think we will specify 3000K because that’s what we have now and are happy with it. Actually, I wanted to mix and also create scenes with 2700K or even lower for the living room, office, and bedroom. But that gives him the creeps (even though I didn’t understand why).
11ant16 Mar 2018 19:49
R.Hotzenplotz schrieb:
An expensive choice. I wouldn’t want to have to replace it after a short time just because I don’t like it.
I meant that it’s not a problem to simply choose 3000 K (Kelvin) now wherever you want it, and otherwise follow his suggestion of 2700 K. On one hand, he probably knows what he’s doing – but you are the ones living there. Light bulb fittings are standardized, so you don’t have to commit to one color temperature forever during installation. So it’s just a preference, not a firm decision.
Maria16
16 Mar 2018 19:58
Light bulb sockets are standardized, so you don’t commit to a specific color temperature permanently during installation. Therefore, it’s just a choice, not a decision.
That is no longer entirely true, unfortunately. When you use those fancy LED units with everything built-in, you can only replace the entire fixture...
11ant16 Mar 2018 20:06
Maria16 schrieb:
If you use those fancy LED units where everything is fixed inside, you can only replace the entire lamp...
... or you confront the designer until they understand why standards exist: for modularity, such as being able to separate the socket from the bulb. This should apply just as much to apples as it used to for the pear, otherwise this modern stuff is just junk.
Lighting your home is essential. It must not fail because of a confusing mess like the one created with mobile phone chargers.
Within each category—bulb, halogen, LED—the system must be flexible, otherwise it is a design flaw.
