ᐅ My KALLAX used as a recessed shelf does not sit flush against the wall – how to avoid gaps?
Created on: 22 Feb 2016 08:23
lismuHello everyone,
I have an issue with my KALLAX shelf from IKEA, which I installed as a built-in unit in a niche. Unfortunately, it doesn’t fit flush against the wall, leaving a small gap visible on the side. The niche opening is apparently slightly wider than the shelf, which looks annoying and also somewhat affects the stability.
My question to you is: How can I minimize or completely eliminate these gaps so they are hardly visible? Are there any proven methods or tools to fit the KALLAX precisely into a European standard niche? I’m thinking about possible adjustments to the wall or the shelf itself, but also about cladding or sealing options.
Who has experience with this and can offer advice on how to fit the KALLAX as tightly and accurately as possible against a wall in a niche, without compromising stability or requiring too much effort? Many thanks in advance!
NoValentin22 Feb 2016 09:11Gaps behind the KALLAX can be filled with suitable wooden wedges or thin assembly putty. If the wall is uneven, check it with a spirit level before installation and, if necessary, even out with filler compound. Alternatively, thin shadow gap strips are a good solution to visually conceal the gap.
There are basically two approaches to the issue of gaps between a KALLAX as a niche shelf and the wall:
Firstly, the precision of the niche is crucial, since IKEA modules have a standardized width. The niche should be matched as closely as possible to the module width. If this is not the case, the following solutions are recommended:
1. Covering the sides with MDF strips, painted or laminated to match the KALLAX finish. These strips can visually close the gap between the wall and the outer edge of the shelf in a coherent way.
2. Silicone or acrylic sealants are very flexible and prevent dust buildup between the wall and the shelf.
3. If structural measures are possible, gaps in the wall could be corrected using drywall patches.
It is important that these adjustments do not compromise stability. The shelf should always have a secure footing, especially when stacked high.
lismu schrieb:– this is a typical case where simple covering solutions make the most sense.
It’s interesting that you mention gaps caused by the difference between the KALLAX unit and the niche width. This raises the question of whether the issue might actually be due to an irregularity in the niche itself. After all, furniture like the KALLAX, which is hardly adjustable, is generally not designed for recessed installation.
This is exactly the point: if the niche is significantly wider, it is difficult to fit the furniture flush against the wall—let alone achieving a millimeter-precise installation.
I would also recommend checking the wall: is it truly at a right angle? Unevenness on one side can cause a visible gap. Measuring again with a bevel gauge or a digital angle measuring tool can clarify this.
Additionally, you could consider whether the shelf unit itself could be slightly trimmed or modified on the side. I know this goes against the standard IKEA solution, but sometimes a bit of effort is worthwhile for a visually perfect result.
Finally, it’s worth asking:
- Is the gap really a problem for you, visually or functionally, that justifies an elaborate solution?
- How wide are the gaps exactly? Often, it makes more sense to add a subtle trim piece instead of altering the shelving unit.
bupar schrieb:
The niche should be as closely matched to the module width as possible.
Hello lismu,
I’m very familiar with your issue, as I installed my KALLAX as a recessed shelf in an opening that was almost the right size. There are several practical ways to avoid gaps:
1. Use thin spacers or wooden strips that you can paint with spray paint to match the shelf. You can attach these from the back or side to fill small gaps. Make sure the strips are securely screwed to the wall or the furniture to prevent the shelf from wobbling.
2. Check the wall for unevenness. Gaps are often noticeable due to minor irregularities that can be corrected, for example with a thin layer of plaster or filler.
3. If the gap runs along the entire height of the shelf, you can install shadow gap moldings made of wood. They are thin, decorative, and cover joints so that they are barely visible.
4. Also pay attention to the floor. Sometimes the shelf is slightly tilted, causing gaps to appear at the top or bottom. Small, cut-to-size felt pads can help level the height here.
Personally, I would avoid cutting the KALLAX. It is built quite sturdy, but modifications could affect its stability.
If you have any more questions, feel free to ask!
