ᐅ Is the KALLAX too unstable to use as a TV stand for a large television?
Created on: 17 Jul 2022 09:17
FODOLOI am considering using my IKEA KALLAX as a TV stand for my new large television but have some concerns about its stability. My TV is 65 inches and weighs around 18 kg (40 lbs) – is the KALLAX unit stable enough for this, especially if it’s used only as a base? I’m particularly interested in how the construction holds up in everyday use with such a heavy device. Has anyone had experience using the KALLAX as a TV stand for large TVs, or does it quickly become problematic due to insufficient stability? Are there any tips on making the unit safer without major modifications?
Very good point regarding stability. Essentially, the KALLAX is designed for lighter items, not as a TV stand for a 65-inch TV. I recommend:
1. Check the maximum load capacity according to IKEA (usually around 13-15 kg per compartment).
2. Position the TV centrally to ensure even weight distribution.
3. Add reinforcements such as an extra wooden board on top, which significantly increases stability.
Without these measures, there is a risk that the KALLAX will sag or that the material may get damaged. For those wanting to be safe, it is best to choose a TV stand specifically designed for this purpose.
Haha, I once temporarily used my KALLAX as a TV stand 😊. Sure, it can support the weight, but it does feel a bit wobbly with a 65-inch (165 cm) TV on top! My advice: place something sturdy underneath to reduce the direct load on the shelf. And hey, with some nice decoration, you can also visually mask the stability issue 😉.
I believe the claim that KALLAX is stable enough for 65-inch TVs should be critically examined. The design is intended for light loads, especially for the shelves. The top surface is not solid enough to safely support the weight of an 18-kg (40 lb) TV long-term without bending. Manufacturer specifications on this are also rarely available. Therefore, reinforcing or stiffening the surface would be advisable if you prefer not to buy one of the specialized TV furniture options.
