ᐅ My KALLAX always feels slightly sticky, even after cleaning—is this something you’ve experienced too?
Created on: 3 Feb 2019 08:43
mentorme
Hello everyone, I have been experiencing an issue for some time now where my KALLAX shelf from IKEA remains slightly sticky despite regular cleaning. I use common cleaning products such as all-purpose cleaner or even some dish soap with water, but the surface never feels completely clean and still sticks a little. Does anyone have experience with this phenomenon? Could it be due to the material properties, or are there any specific tips on how to permanently remove this unpleasant stickiness? I would appreciate helpful advice and a detailed explanation of what might be causing this from a technical or chemical perspective.
mentorme
3 Feb 2019 13:05
elliot schrieb:
If the stickiness remains, it could also be caused by a defective or low-quality paint film
Thank you for the suggestion; I hadn’t specifically considered the paint film before. However, my shelf has no visible damage. Do you think chemical cleaning agents could affect the protective coating? And how often can one safely use isopropanol without damaging the veneer or the surface? This information would be important for me so that I don’t unintentionally cause further damage.
V
vinli
3 Feb 2019 13:47
mentorme schrieb:
How often can you use isopropanol without damaging the veneer?
Isopropanol can damage the surface if used too frequently or at high concentrations. Using it every few weeks at a low concentration (around 70%) is generally safe. It is important to wipe the surface afterward with a damp cloth to avoid leaving any residue. Intensive cleaning with alcohol should be reserved for occasional use.
elliot
3 Feb 2019 14:21
mentorme schrieb:
Do you think chemical cleaners can damage the paint film?
Yes, aggressive cleaners, especially those containing solvents or strong alkaline components, can damage the surface and leave sticky residues if not thoroughly rinsed off. It’s best to use mild cleaning agents and always wipe down thoroughly afterward.
PERON
4 Feb 2019 09:12
Hey, I had exactly the same issue with my KALLAX. I tried using diluted dishwasher rinse aid – sounds strange, but it significantly reduced the sticky film for me. It somehow gives the surface a smoother feel. 🙂 Just make sure to wipe it off thoroughly afterward!
Garry
4 Feb 2019 10:07
The tip mentioned by PERON regarding rinse aid is interesting. From a chemical standpoint, rinse aids often contain surfactants that can break down greasy and sticky residues. However, you should avoid using harsh substances on wood veneers or melamine-coated panels, as these could damage the finish. It is advisable to test the product on an inconspicuous area first to avoid any potential damage.
mentorme
4 Feb 2019 17:44
Thank you all for the helpful responses! I will start by using mild cleaning agents with plain water, and then possibly try some isopropanol carefully. The tip about using rinse aid sounds interesting, and I will test it very cautiously and in small areas. Thanks also for the dosage and application advice! I’m glad to receive such practical and well-founded feedback here in the forum. If anyone has experience with long-term maintenance, please feel free to share.
