ᐅ How can I properly clean BILLY shelves without damaging the surface?
Created on: 13 Feb 2022 08:17
Nafe2
I have a question regarding the cleaning of IKEA Billy shelves. These shelves have a coated surface – often melamine-coated or covered with a laminate film. Now, I’m wondering: how can I clean Billy shelves properly without damaging the surface or causing unattractive scratches or peeling?
I am particularly interested in which cleaning agents are recommended, whether to use damp or dry cloths, and if certain cleaning tools should be avoided to protect the material.
Does anyone have experience or tips, maybe even advice on long-term maintenance to keep the shelves looking good? I would appreciate a detailed response, as I want to avoid risking damage to the surface from improper cleaning.
draFrederi13 Feb 2022 16:49Hi Nafe2 and readers! 🙂
I admit – cleaning can get a bit rough sometimes. But when it comes to Billy shelves, it’s really worth being a bit careful.
A quick tip from experience: Only use soft cloths, and avoid chasing stubborn dirt with abrasive cleaners or rough sponges!
Exactly that – I almost ruined my first Billy shelf by cleaning too aggressively while trying to remove tough stains. Now I stick to gentle care.
One more bonus: If you wipe the shelf regularly and gently, you won’t need strong products and you’ll avoid damage in the long run.
Good luck with cleaning – and stay patient! 😉
tolokau schrieb:
4. Avoid: No abrasive sponges, steel wool, or harsh chemicals.
Thank you very much for the many helpful replies so far.
I have a further question: If I have stains caused, for example, by grease or label residue, what is the best way to clean them without damaging the surface? Is a mild dish detergent really sufficient in this case?
Also, what about using vinegar or vinegar concentrate? I sometimes read these are home remedies that work well against lime scale – are they suitable for BILLY shelves, or do they damage the coating?
Timmyse3614 Feb 2022 10:12Regarding your question: I have usually been able to remove grease residues well with a mild dish soap and water mixture. For label residue, I sometimes use lukewarm water and let the cloth soak for a longer time to dissolve the adhesive.
I have not used vinegar on BILLY because I am concerned that the acidity could damage the laminate.
My recommendation: It’s better to avoid these to prevent damaging the surfaces. Instead, you might want to try specialized furniture cleaners for coated surfaces, as they are often formulated to be gentle.
Nafe2 schrieb:
What about using vinegar or vinegar essence?
Vinegar or acidic cleaners should be avoided on BILLY shelves. The surface is delicate and may be damaged.
For stubborn residue, I recommend gently applying mild solvents such as isopropanol, used sparingly and wiped off immediately with a damp cloth. Test this first on a hidden area!
Sustainable cleaning tips to finish:
- Generally avoid acidic cleaners like vinegar or citric acid, as they can damage the plastic coating.
- For grease stains, mild soap and water is often sufficient.
- Adhesive residues (e.g., from labels) can be gently treated with a cotton cloth and some isopropanol, followed immediately by wiping with water.
- Always test first in an inconspicuous area.
- Avoid prolonged exposure to liquids that could seep into the edges.
This way, the shelves will remain visually appealing and undamaged for a long time.
JEREMIAH3815 Feb 2022 16:43A personal experience: I once had a rather stubborn stain on my BILLY shelf and was initially unsure how to remove it. I then carefully tried using some mild dish soap and lukewarm water. This worked well without leaving any stains or damage.
It’s true that the surface coating is somewhat sensitive. That’s why I appreciate that the recommended method involves gentle cleaning agents and a cautious approach.
I completely agree — better to be cautious than regret it later.
Thanks to everyone for the tips here, I now feel well prepared for the next cleaning session! :-)
Timmyse36 schrieb:
I didn’t use vinegar on BILLY because I worry that the acid might damage the veneer.
