ᐅ How can I clean Billy shelves when they have stubborn dirt?
Created on: 1 Jan 2020 09:12
klodi
klodi
1 Jan 2020 09:12
Hello everyone, I have a somewhat specific problem with my Billy shelves from IKEA: In some corners and along the edges, stubborn dirt has accumulated that cannot be easily removed with a damp cloth or standard cleaning products.
My question: What is the best way to clean Billy shelves with stubborn dirt without damaging the surface? Are there any proven techniques or home remedies you would recommend, especially for these typical white laminated surfaces? I would appreciate tips on how to thoroughly and gently clean the shelves, even when the dirt is really dried in.
GLALEO
1 Jan 2020 09:35
Hey klodi, it’s great to see you taking such a detailed approach with the Billy shelves! 🙂
I’ve had good results using a mix of warm water and a little dish soap. Just take a sponge, wring it out well, and patiently clean the corners.
If the dirt is particularly stubborn, try a microfiber cloth with some vinegar diluted in water – that usually works well! But be careful not to use too much vinegar, and always test on an inconspicuous spot first to avoid damaging the finish. Good luck, it will definitely look great again! ;-)
Samuel
1 Jan 2020 10:07
Hi klodi :-)
Your question is very precise! I once had the same problem with a dried coffee stain and did the following: Mix some baking powder with water until it forms a paste, apply this to the stained area, and let it sit for a short time.
Then gently wipe it off with a damp cloth. Be careful not to rub too hard to avoid damaging the laminate layer.
The baking powder acts as a mild abrasive without ruining the surface and often gives great results – give it a try! 🙂
nubar
1 Jan 2020 11:45
Dirt on laminated Billy shelves can often be effectively removed with a special upholstery foam cleaner, especially for stubborn stains, because it gently cleans and penetrates fibers or pores—even though the surface is actually smooth.
If you don't have such a foam cleaner, a soft white eraser (non-abrasive) can help carefully without damaging the surface. However, test this first on an inconspicuous area.
PLOMA
1 Jan 2020 14:22
Hello klodi,
To efficiently and gently remove stubborn dirt from Billy shelves, a multi-step process is recommended:
1. First, mechanically remove coarse dirt using a microfiber cloth with lukewarm water and mild dish soap, making sure the cloth is not too wet.
2. For dried-in stains, I suggest a paste made from baking soda and water. Let the paste sit for a maximum of 15 minutes, then gently wipe it off with a damp cloth.
3. For tougher stains, you can use isopropyl alcohol (around 70%). Apply it to a cotton cloth and rub carefully – it dissolves grease and discoloration without damaging the laminate surface. Be sure to test first to ensure the surface remains unharmed.
4. Do not use abrasive sponges or harsh cleaning agents (such as bleach or ammonia), as these can damage the surface.
5. Finally, wipe with clean water and polish with a dry cloth to prevent water spots.
I’m curious about how stubborn the dirt exactly is: Is it grease, dried dust, or other substances? This would influence the choice of cleaning method.
klodi
1 Jan 2020 15:11
PLOMA schrieb:
I’m curious about how stubborn the dirt actually is: Is it grease, dried dust, or other substances?
Thank you for the detailed explanation! To answer your question: It is mainly dust and dried small splashes (probably coffee or juice) that have partly been “stored” in the corners of the shelves over a longer period. I wouldn’t describe it as greasy or oily, but rather as stale residues that have become somewhat set.
