ᐅ How can you maintain the color of BILLY shelves over the long term?
Created on: 11 Jun 2024 08:43
Gabrielafr
Hello everyone, some time ago I bought a few Billy bookcases from IKEA and I am actually very satisfied with the design and practicality. However, I noticed that the surface color becomes somewhat dull after a while and shows small signs of wear in some areas. I am therefore very interested in how to maintain the color or finish of these shelves over the long term.
Specifically, I mean which cleaning and care products are suitable, whether the surfaces can possibly be treated with certain substances, and what the best approach is to prevent color changes or wear.
Does anyone have experience with keeping the look of a BILLY bookcase fresh and vibrant over the years? I look forward to your tips and advice!
Hi everyone!
I find your information really helpful, especially the tip about the UV protective film—it sounds great! A little secret tip from me: if you like, you can gently dust the shelf from time to time with a dry microfiber cloth. This helps maintain the shine and keeps it looking fresh.
Oh, and don’t worry too much about maintenance: years ago, I had a small mishap with a furniture care product—the result wasn’t perfect, but definitely not a disaster! 🙂 Just don’t overdo it and treat it lightly and regularly rather than intensely and rarely.
By the way, if you don’t clean the shelf often, dust quickly accumulates, making the surface look dull. So a bit of regular care really helps.
Good luck and best wishes for maintaining color and shine 😉
I can add some technical details regarding color and surface care for Billy shelves.
Melamine resin coatings are relatively durable, but there are different quality levels. At IKEA, this is standard and generally works well, but the surface consists of a composite material with paper as the base and melamine as the top layer.
Over time, chemical substances such as cleaning agents containing ammonia or solvents can damage or dull the melamine surface. In addition, micro-scratches can occur that refract light and create the impression of color fading or a “dusty” appearance.
My recommendations:
- Use isopropanol (70%) very sparingly and only spot-treat stubborn stains, as this alcohol can damage the finish.
- Regularly wipe gently with a soft, damp cloth without any additives.
- Avoid wiping directly with cold water, since temperature shocks can cause fine cracks.
- For visible scratches, I have always carefully used very fine abrasive pads, followed by treating the area with furniture polish to counteract the faded white appearance.
I’m interested to know if you, @Gabrielafr, perhaps put more strain on the shelves’ sides or back panels? These are often coated more thinly and are less durable than the visible front surfaces.
My recommendations:
Gabrielafr11 Jun 2024 13:40Filippo schrieb:
I am curious whether you, @Gabrielafr, might also put more stress on the sides or back panels of the shelf?Good question! The sides are usually less affected, but in some spots where, for example, books are tightly packed together or I occasionally bump into them lightly, there are already minor scratches visible. The back panel hardly shows any wear as it is placed directly against the wall.
What do you think about adding extra protection to the sides with thin protective films? Would that be technically advisable, or could it actually damage the surface if the films are not breathable?
Gabrielafr schrieb:
What do you think about adding extra protection to the sides with thin protective films?This is a double-edged sword. Protective films can indeed guard against mechanical abrasion, but they need to be specifically designed for furniture surfaces. Regular plastic films are usually not breathable and can trap moisture, which may cause swelling in particleboard.
Better options are breathable films developed for furniture or plastic surfaces. Alternatively, you can use edge protectors made for furniture; these mechanically protect the edges and usually look quite good as well.
If you decide to use films, be sure to check the compatibility of the adhesive with melamine surfaces—some adhesives can damage the color or make removal difficult later on.
If the shelves are placed in a normal living area and not subjected to heavy use, gentle regular care and avoiding direct physical pressure are generally sufficient.
I would like to add that patience is important when it comes to maintenance. Sometimes we overthink things and try every possible remedy, but natural use will eventually leave its marks.
I always find it best to care for furniture consciously, without being overly cautious. And not treating it like a holy grail. 🙂
And if the color does fade at some point: A fresh coat of suitable paint (e.g., acrylic lacquer in white, which works well on melamine) can do wonders, especially for BILLY shelves, which are relatively affordable.
This way, I find it easier to mentally accept minor flaws.
