I have a question regarding my Ikea Billy shelves: They are placed in a room with large windows that let in a lot of sunlight, especially in the afternoon. Since the shelves are made of laminated particleboard, I'm concerned about possible UV damage such as fading or material changes.
My question to you is: How can I best protect Billy shelves from UV damage? Are there practical and visually appealing methods that have proven effective for home use?
I would appreciate any tips on UV protection films, special care, or other solutions. Thanks in advance!
Hello lapeo62,
I completely understand your concern! 😎 UV radiation can really cause the surface of Billy shelves to fade, especially when they are placed in direct sunlight.
What worked for me was applying a UV protection film to the windows. It’s transparent, lets the light in nicely, and filters out the UV portion. This not only protects the furniture but also your skin 😉
Alternatively, thin curtains or blinds that you use during the day can help as well. This way, the shelves receive slightly less sunlight but are protected from UV and still well-lit.
Maybe you could just install such a film on the windows? This is usually the simplest solution.
I would like to add something, as the topic of UV protection for furniture is often underestimated.
Besides UV-protective films for windows, there are also special furniture care products with UV-blocking ingredients. These are often available as wax or spray and form a protective layer on the surface. It is important, however, that they are truly suitable for laminate, as you don’t want to alter the appearance.
In addition, mirrors or real wooden furniture should be placed on the opposite side — this helps reduce direct sunlight around the piece of furniture.
It is important both to reduce sunlight exposure and to maintain the shelf regularly. This way, you can extend its lifespan.
Thanks in advance for your answers!
@mauka: The idea of using a UV protection film sounds very practical. What should I look for when buying one? Are there specific materials or specifications you would recommend?
@benon: Furniture care products with UV protection sound promising. However, I have no experience with how often these products should be applied or whether they really preserve the laminate appearance. Do you have more detailed information or even product recommendations?
I’m curious to hear your thoughts before I decide to get anything.
I’ll summarize the technical background for your question, @lapeo62.
UV radiation is mainly filtered by window glass but not completely. In apartments, especially with large panoramic windows, the exposure to furniture is relatively high. Laminate and melamine coatings, like those on Billy shelves, can fade or become brittle as a result.
UV protection films:
- Pay attention to the UV-A and UV-B filter levels; ideally, products with over 99% UV blockage.
- Adhesion quality is important: bubble-free films are preferable.
- Some films also reduce heat, which protects furniture and saves energy.
Furniture care:
- There are special nanoparticle-based UV blockers, often available as sprays. They form a micro-thin protective layer.
- For laminate, the effect is not as long-lasting as for wood, but regular application (every 3–6 months) can help.
Window curtains made of dense, light-blocking fabric are also an option to combine effective UV protection with natural light.
One more question for you: How much direct sunlight does the shelf receive daily? Is it exposed to strong sunlight continuously or only for a few hours? This makes a big difference when choosing protective measures.
Furniture care:
kulau schrieb:
One more question for you: How much direct sunlight does the shelf get daily? Is it exposed to strong sunlight all day or only for a few hours?Good question, thanks! The shelf is located on a southwest-facing side, where sunlight shines directly in especially in the afternoon and evening – roughly 3-4 hours of full sun per day, depending on the weather. In the morning, it mostly gets indirect light.
