ᐅ Billy Regal balcony furniture version – how to make it weather-resistant?
Created on: 22 Oct 2023 08:37
SHAYAN54
Good morning everyone, I recently purchased the Billy shelf balcony furniture version because I really appreciate its simple design and functionality. Now I’m wondering how to make this furniture as weather-resistant as possible so it can last through typical balcony weather – that is, alternating rain, wind, occasional frost, and other moisture. I want to avoid the wood swelling or discoloring, and the joints should remain stable as well. What methods and products would you recommend to minimize weather-related wear and tear? I’m especially interested in your advice regarding surface treatments, impregnations, and possibly additional weather protection measures like covers or roofing. Thanks in advance!
Regarding weather resistance of Billy bookcases: these pieces of furniture are designed for indoor use and are often made of painted particleboard or MDF. It is essential to understand that prolonged outdoor exposure will damage their structure.
For acceptable protection, the following is recommended:
- Degreasing and lightly sanding the surface
- Applying at least two coats of a high-quality, breathable wood preservative (e.g., water-based)
- Carefully sealing all cut edges and drill holes
- Using a UV-resistant clear varnish as a surface sealant
Covers made of breathable material prevent mold growth better than plastic covers alone. The furniture should be elevated to avoid standing water.
There is no guarantee of complete weather resistance with these materials.
Why use the Billy shelf on the balcony at all? That’s quite careless.
Exactly, it’s better to choose the right outdoor furniture right away. In the long run, it pays off since the materials and design are suited for weather exposure and wear.
Who wants to keep repainting every year? That’s a waste of time. And honestly – the Billy style works indoors, not in heavy rain.
BAUEVA schrieb:
In my opinion, you should either buy furniture designed for outdoor use from the start
Thank you for the initial feedback. I now have a better understanding that the material used in Billy-style outdoor units is not ideal. However, I would like to know more specifically: How would you treat a finished wood surface, and what products do you recommend? For example, should I use a wood stain in certain colors, or would a clear finish be better? Are there special primers to apply before staining that provide extra protection for the wood? How often should this treatment be repeated, especially considering changing weather conditions on a balcony?
I am also interested in whether there are recommended methods to protect screw connections from corrosion and to minimize moisture penetration. Thanks!
PeoDaniel22 Oct 2023 14:05Regarding surface treatment: It depends on how much you want to preserve the natural character of the wood. Clear finishes are good for maintaining the appearance, but some wood stains come in tinted options with added UV filters that reduce material aging.
A primer is only necessary on untreated wood – but MDF or chipboard is usually already primed. Applying a primer before the stain can improve adhesion and increase protection.
I recommend wood stains with microporous technology that allow moisture to escape, preventing the wood from swelling.
Reminder: Usually, sanding and re-staining once a year or before each new outdoor season is sufficient. Depending on location and sun exposure, it may be necessary more often.
Exactly, regular inspection is important.
Regarding screws: Use galvanized or stainless steel screws that won’t rust. For the holes, you can also use small rubber washers or sealants to keep water out.
SHAYAN54 schrieb:
How often should I repeat this, especially with changing weather conditions on the balcony?
Z
zarHenning22 Oct 2023 15:42WD40 or similar products on screws help prevent rust. Plastic washers offer additional protection.
