ᐅ Is there a way to protect Billy shelves from discoloration?
Created on: 12 Jan 2022 08:34
ChenenyaHello everyone,
I have several Billy shelves from Ikea at home, and I’ve noticed that the white surfaces tend to discolor over time, especially on the sides and the shelves. I mainly use the shelves to store books, binders, and some decoration, and sometimes I also place plants on them. So I’m wondering: is there a way to protect Billy shelves from such discoloration in the long term?
I would like to know if there are suitable protective products, special films, or care methods that preserve the appearance without damaging the material. From experience, furniture like this is often somewhat sensitive to UV exposure, moisture, or even dirty fingers—so I would also appreciate cleaning tips that don’t cause damage.
If anyone in the forum has practical knowledge or recommendations, I would be very grateful if you could share them with me. Thank you!
Chenenya schrieb:
What options are there to protect Billy shelves from discoloration over the long term?Interesting question, but I would first like to better understand the specific type of discoloration occurring. Is it yellowing from sunlight exposure, stains from liquids, or marks caused by objects?
Without identifying the exact cause, any attempt at protection makes little sense and could even be counterproductive.
I have read from users claiming that a UV protective film on the panels can be helpful, but I doubt how practical this is for open shelves.
I would appreciate it if someone could share detailed experiences regarding the causes, so we can focus more effectively on protection methods.
Linavin schrieb:
A UV protection film on open shelves is not really practical.I agree. Based on my research, the main issue with Billy shelves is often slight yellowing caused by UV exposure and occasional stains from moisture or dirt.
To prevent this, I recommend the following measures:
1. Location: Do not place the shelf in direct sunlight.
2. Cleaning: Use only a damp cloth and mild soap, avoid abrasive cleaners.
3. Surface protection: There are clear furniture polishes or protective coatings for laminate that can be applied thinly. However, you should test on an inconspicuous area first to ensure the finish is not damaged.
Permanent sealing is technically possible, but Ikea furniture is not designed for this and may be damaged by inappropriate products.
Friedrich12 Jan 2022 13:18I can definitely understand how frustrating it is when furniture starts to look unattractive. I have also noticed after a few years that my Billy bookcases develop small yellowish spots and discoloration, even though I regularly clean them over time.
Maybe some small precautions in between can help as well: For example, I use thin liners or fabrics between the shelves and certain items when placing something that might transfer color—such as small plant saucers or specific decorations.
This definitely helped me because sunlight actually has the biggest impact on color changes.
I would also appreciate it if others could share their experiences, so we can gain a bit of confidence to keep using these shelves :-)
Joshbe schrieb:
Do not place the shelf directly in the sunlight.
Marlenepa12 Jan 2022 15:07Hello everyone!
I would like to revisit the topic of cleaning and maintenance, as I often see that the wrong cleaning products cause much more damage than natural discoloration.
Basically, for Billy shelves, a soft, slightly damp microfiber cloth with a little mild dish soap is recommended. After wiping, the surface should be quickly wiped again with a dry cloth to avoid moisture residue, which can later cause stains.
I think that is a very good idea, especially with plants, as these, as is well known, release moisture that can easily penetrate the shelf material.
One more tip: Sometimes I use furniture oils or special care waxes for laminate, which help to refresh the shine and protective layer a bit. However, use should be minimal and always tested first.
Friedrich schrieb:
Use soft pads or cloths between the shelves and certain items.
To effectively prevent discoloration of Billy shelves, it is important to understand the material and its vulnerabilities.
Billy shelves are made of particleboard with a melamine resin coating. This material is generally quite durable but sensitive to heat, light, and moisture. UV radiation triggers chemical reactions that cause yellowing.
One possible protective measure is a transparent water-based spray containing UV blockers. However, it is important to ensure that it is suitable for melamine, as otherwise the surface may become cloudy or sticky.
Additionally, regular cleaning with appropriate products is crucial. I would advise against oily polishes, as they can attract dirt and damage the surface despite the care.
I have one more question: Are the shelves permanently placed in a spot with direct sunlight, or do their locations change? This greatly affects the choice of the right protection.
