ᐅ Is there a way to protect Billy shelves from discoloration?
Created on: 12 Jan 2022 08:34
Chenenya
I have several Billy shelves from Ikea at home, and I’ve noticed that the white surfaces tend to discolor over time, especially on the sides and the shelves. I mainly use the shelves to store books, binders, and some decoration, and sometimes I also place plants on them. So I’m wondering: is there a way to protect Billy shelves from such discoloration in the long term?
I would like to know if there are suitable protective products, special films, or care methods that preserve the appearance without damaging the material. From experience, furniture like this is often somewhat sensitive to UV exposure, moisture, or even dirty fingers—so I would also appreciate cleaning tips that don’t cause damage.
If anyone in the forum has practical knowledge or recommendations, I would be very grateful if you could share them with me. Thank you!
Surela schrieb:
Are the shelves permanently placed in a spot with direct sunlight?Thanks for the question, it’s actually relevant: My shelves are in the living room, with a large window facing south, but the shelves are positioned a few meters away from the direct glass surface. Still, they receive plenty of indirect sunlight during the day.
So, UV protection would be a factor. However, the shelves remain fixed in their spot and are rarely moved.
Linavin schrieb:
Is it about yellowing caused by sunlight, stains from liquids, or marks left by objects?For me, it’s a mix: slight yellowing on the edges and front parts of the shelves, as well as some spot stains, probably caused by water from flower vases or plant coasters.
I was hoping there might be a simple protective cover or solution that can be applied regularly without too much effort or negatively affecting the appearance.
A practical way to protect Billy shelves can actually be a matte, self-adhesive protective film. Such films are available, for example, in PVC or polypropylene, which filter UV rays and also protect against liquids.
It is important that the film is as thin and transparent as possible so that it does not significantly alter the appearance. Additionally, it can be removed without leaving any residue if you want to replace it later.
These films are relatively easy to maintain and can be applied after cleaning the shelf beforehand.
Besides protecting against stains, the film also prevents small scratches that would otherwise become noticeable quickly.
Chenenya schrieb:
Hoffte auf eine einfache Schutzabdeckung ohne zu großen Aufwand oder optischen Verlust.
As an additional note, if you plan to treat the shelves with any protective varnishes or polishes, the products must be specifically approved for melamine-coated surfaces.
Many common furniture care products are not suitable for melamine surfaces and can cause stress cracks, peeling, or clouding.
An alternative is special polyurethane (PU)-based sealants, which should only be applied by professionals with the appropriate experience, as improper application can result in an uneven finish.
For home use, the safest and most cost-effective approach is likely a combination of optimal placement, regular gentle cleaning, and optionally a protective film.
I would like to add a small tip that has worked well for me: I use simple plastic mats made of clear silicone or rubber between the shelves and plants or damp items. These prevent moisture from reaching the surface directly.
I can only confirm this, as mechanical stress or cleaning products containing alcohol or solvents quickly damage the melamine coating.
Additionally, I recommend dusting the shelves and removing moisture at least once a month to significantly extend their lifespan.
Marlenepa schrieb:
Use a soft damp cloth with mild soap, then follow with a dry cloth
Chenenya schrieb:
Shelves receive indirect sunlight and show a combination of discoloration and localized spots.Thank you for the additional information! In this case, besides using a UV-protective film, you might also consider so-called clear coat finishes designed specifically for furniture.
The process would be:
1. Thoroughly clean the furniture
2. Apply a thin layer of protective varnish and allow it to dry carefully
3. Apply a protective film if you want to be extra cautious
Although this may sound elaborate, it is a combination of chemical and physical protection that can extend the lifespan of the furniture.
If you are interested in this approach, I can provide more detailed product recommendations that are compatible with melamine.
