I have several Billy shelves from IKEA that I would like to place in a room with a lot of sunlight. My main concern is that the wood or surface may turn yellowish and brittle over time due to UV exposure.
My question to you is: How can I best protect Billy shelves from UV damage without significantly altering their appearance? Are there specific sealants or films that work well? I want to preserve the original look as much as possible while extending the lifespan of the shelves.
Which methods or products have you found effective?
Thanks in advance for your tips and experiences!
Hello hauru2, here is a structured approach to protect BILLY shelves from UV damage:
1. Window UV protection film: As mentioned several times, install it. Important: Use a high-quality film with strong UV filtering performance (≥ 99%), suitable for residential use.
2. Prepare furniture surface: Since melamine coatings are difficult to treat, special bonding primers are recommended to enable an additional layer.
3. UV-resistant clear coat: Use a clear coat specifically designed for furniture with plastic surfaces. Acrylic resin lacquers are preferred here.
4. Application: Apply thinly and evenly, ideally in several thin layers with drying time in between.
5. Alternative: Use accessories such as curtains or blinds simultaneously – especially for south-facing windows.
6. Distance from the window: It often helps to position the shelf a few centimeters (inches) away from the windowpane to reduce direct exposure somewhat.
Summary: A combination of UV protection film + optional coating + positional adjustment offers the best protection.
If you prefer not to do any coating work, limit yourself to UV film and room layout.
Hey hauru2! 🙂
Your concern about the BILLY shelves and UV damage is totally understandable. Who wants yellowed or brittle shelves?
That’s exactly what I would recommend too – but make sure you use a clear coat suitable for plastics and that doesn’t have a yellow tint.
If you’re interested, you could combine this DIY project with a small sunshade at the window – it looks stylish and provides protection without having to apply window film.
And don’t worry, you’re not alone with your shelf problem – after summer, my apartment often looks like an Ikea warehouse with sunburn 😉
But seriously, it’s great that you’re tackling this now! If you want, I can send you some tips later on how to apply clear coat properly to keep everything looking smooth.
GiRoyce schrieb:
Water-based UV-resistant clear coats help protect the surface from sun damage
hauru2 schrieb:
I am mainly looking for a varnish that does not yellow and can be applied as thinly as possibleHello, I recommend the varnish products "Clou Klarlack UV-Plus" or "Osmo UV-Coating" – both are designed for increased UV resistance and do not leave a strong yellow tint, especially in transparent versions.
Applying a thin layer is important because thick layers tend to be easier to notice or may peel. It’s best to use a high-quality brush or a small roller for an even finish.
Another tip: Before varnishing, lightly roughen the surface to improve adhesion, even on melamine-coated surfaces. This enhances the durability of the protective film.
If you want to pretreat the shelf somewhere, I also recommend testing on a small, less visible area first.
Palenar schrieb:
Is the shelf exposed to sunlight constantly, or only during certain times of the day? It is actually exposed throughout the day, for example in the morning and afternoon, but not continuously. The sunlight is especially strong in the morning as the window faces east.
Nabla64 schrieb:
Apply thinly and evenly, ideally in several thin layers with drying time in between. That sounds like a good approach, which I could also apply to small surfaces.
My plan now is: first UV protective film on the window, then possibly clear lacquer on the surfaces. Thanks for the tips so far! Do I need a separate primer for lacquers at all, or is plain clear lacquer sufficient on melamine-coated boards?
hauru2 schrieb:
Do I really need a separate primer for paints, or is clearcoat alone sufficient for melamine-coated boards?Good question!
Melamine is well known for being very durable and smooth, so paint adhesion is not guaranteed. A primer ensures that the paint stays permanently on the surface and doesn’t chip off.
Therefore, I recommend applying a primer suitable for plastics before the clearcoat. This is usually transparent and barely changes the appearance. Without a primer, you will very likely have problems with durability, especially under mechanical stress.
If you choose a product that has the primer “integrated” (2-component systems), you can skip that step.
Alternatively, very fine sandpaper (around grit 400–600) can help to roughen the smooth surface—but be careful regarding the appearance and dust contamination!
It also depends somewhat on how heavily the shelf will be used (e.g., whether books are regularly placed on and taken off).
