ᐅ How do you best protect Malm furniture from moisture?
Created on: 6 Dec 2022 10:22
Piboma
Hello everyone, I recently bought a Malm piece of furniture from Ikea and am wondering how to best protect it from moisture. The furniture is placed in a room that becomes somewhat humid during winter, and I want to avoid the surface swelling or warping. Are there any proven methods or products to effectively protect Malm furniture against moisture without affecting its appearance? Any tips on proper care in damp environments would also be very helpful.
Garry
6 Dec 2022 15:25
I have had good experiences using a combination of a dehumidifier and special furniture care oils. It is important to apply the oils sparingly to avoid oversaturating the surface.
Although Malm furniture has a foil coating, oil does not seal it but rather enhances moisture protection through light impregnation.
In a home with average indoor humidity, the furniture should not cause any problems.
CHENFAR
7 Dec 2022 08:47
Regarding moisture protection for Malm furniture, the following should be considered:
The particleboard used as the core material tends to absorb moisture. The foil coating is only a thin layer and does not fully withstand mechanical stress and moisture over time.
Therefore, a dual approach is recommended: 1. Physical protection by avoiding contact with water, and 2. technical measures such as attaching furniture glides to prevent moisture from reaching the floor surface.
Ultimately, no waterproofing treatment can replace proper placement and a well-ventilated room. My tip: combine this with a dehumidifier and treat the edges with clear furniture lacquer for enhanced protection.
lajudo
7 Dec 2022 10:19
In summary: Do not place furniture directly against cold, damp walls. Allow for some air circulation.
Care: Wipe dry only and occasionally use furniture wax. This is not waterproof, but it provides sufficient protection against surface moisture.
Jeanbar
7 Dec 2022 11:33
Hector schrieb:
Are there any reliable long-term studies on the moisture resistance of such furniture?
Currently, there are no comprehensive studies specifically published on Ikea Malm furniture. Due to the industry-standard manufacturing using particleboard and laminate, it is generally known that the protective effect over the medium term cannot be compared to solid wood.
My recommendation remains to protect the furniture from moisture and avoid exposing it to consistently damp conditions. Garry’s point about treating it with furniture oil supports this approach, but caution is necessary, as some oils can damage certain laminate coatings.
Perhaps Piboma could provide information on the exact humidity level of the room? That would help to make a more precise assessment.
Piboma
7 Dec 2022 13:47
Thank you for the many helpful contributions!
About the room: The humidity level in winter is usually between 55 and 65%, which is probably on the higher side. I ventilate regularly, but sometimes the moisture cannot be completely avoided, for example, when drying clothes indoors.
Using a dehumidifier seems like a sensible option, especially to balance out fluctuations.
It also seems important to protect the edges thoroughly, as moisture can penetrate there the quickest, as some have mentioned.
I will probably start with furniture wax and possibly an additional edge sealing, then continue to monitor the situation. Thanks again for the tips!
