ᐅ How can I protect Billy shelves from UV damage?
Created on: 17 Dec 2023 08:13
lapeo62
I have a question regarding my Ikea Billy shelves: They are placed in a room with large windows that let in a lot of sunlight, especially in the afternoon. Since the shelves are made of laminated particleboard, I'm concerned about possible UV damage such as fading or material changes.
My question to you is: How can I best protect Billy shelves from UV damage? Are there practical and visually appealing methods that have proven effective for home use?
I would appreciate any tips on UV protection films, special care, or other solutions. Thanks in advance!
DUVIN
17 Dec 2023 10:45
For your situation, I would recommend window films.
I am not a big fan of furniture care products; they do not last long and are often expensive.
Simply apply a UV protection film with high light transmittance and a UV filter, and that's it.
kaubi
17 Dec 2023 11:18
I’m adding a long-term overview:
UV damage to laminate or particleboard furniture is not only caused by fading but can also lead to hardening or even microcracks on the surface. These damages are subtle but accumulate over time.
The best preventive measure is actually window film, especially for direct west or southwest sunlight. There are also so-called “UV protection varnishes” for furniture: these polyurethane-based coatings create a hard protective layer. However, they slightly change the gloss level, which may or may not be desirable for matte surfaces like those on Billy shelves.
If you plan to rearrange the shelf frequently, a permanent film solution is better than maintenance products.
My recommendation: a combination of:
- High-quality UV protection film (at least 95% UV blocking)
- Light curtains or blinds for flexible light control
- Optional maintenance product applied 1–2 times per year
What kind of glazing do you have on your window: simple insulated glass or special glass with integrated UV protection?
lapeo62
17 Dec 2023 11:45
kaubi schrieb:
What type of glass does your window have: standard insulated glazing or special glass with built-in UV protection?
Thanks, @kaubi! The window has standard double glazing without any special UV coating. Your points about paint and especially film make sense to me.
Your note that some protective coatings can change the gloss is important, as the shelf is matte white. I don’t want a glossy finish there.
Do I need a specific thickness for the film? Are there differences in handling or durability?
benon
17 Dec 2023 12:03
Regarding film thickness: Thickness is usually specified in micrometers. For residential rooms, film thicknesses of 50 to 100 micrometers (0.002 to 0.004 inches) are common and provide good durability without being visibly noticeable on the glass.
Durability: With proper installation, films last 5 to 10 years, but it is important to ensure UV resistance and bubble resistance.
Installation: It is best to have the film applied by professionals, but with some patience and guidance, it can also be done as a DIY project.
Important: Clean the windows thoroughly to avoid trapping dust particles.
I recommend products with warranties and certification seals for UV filtration.
mauka
17 Dec 2023 12:15
One more small addition for those interested in aesthetics 😉
There are also so-called UV protection blinds that you can lower during the day. They act like a kind of shade while still allowing daylight to come in.
Personally, I find this more attractive than a usually barely visible film, because with a blind you can also completely darken the room if you want.
This could be an alternative for days when the sun is especially strong or if you simply want to protect the shelf more. 🙂
kulau
17 Dec 2023 15:28
benon schrieb:
Installation: It’s best to have the film applied by professionals
I agree. Especially with large windows and if you want a bubble-free finish, professional installation is preferable.
A tip for everyday use: dust can settle on the film over time and cause slight dull spots. You should gently clean the film with a suitable microfiber cloth to keep it looking good longer.
The advice about blinds is also useful, but a combination of film plus blinds offers the most protection.
Rotating the shelf after about three years also helps to ensure even fading—if that’s worth it for you ;-)
One more question: How sensitive are you to natural light? Do you want to minimize any reduction in room brightness?
