ᐅ What types of damage occur most quickly to Billy due to improper installation?
Created on: 25 Jul 2024 08:14
Ellie63
Ellie63
25 Jul 2024 08:14
I am currently looking into which damages occur most quickly on the Billy shelf when it is assembled incorrectly. I am particularly interested in damages that become visible relatively soon rather than only after several years. Specifically, I want to know if issues like warping of the shelves, tearing out of the dowel holes, or other structural weaknesses are especially critical in the beginning. Maybe overtightening or undertightening the screws also plays a role.
What experiences have you had with this? Are there common assembly mistakes that immediately cause damage, and if so, which ones? I look forward to your detailed insights so I can be sure to assemble it properly.
SETHBLA
25 Jul 2024 08:48
You will most likely encounter problems if you tighten the screws too much – this often causes the dowel holes to tear out. Incorrect installation of the back panel can also quickly lead to instability.
Filippo
25 Jul 2024 09:12
Hello Ellie63,
I’d like to add some more detailed information about the common damages caused by improper assembly of the Billy shelf.
1. Tearing out of dowel holes:
This often happens when dowels are inserted incorrectly or too deep, and then screws are tightened with too much force. The particleboard in the shelf is relatively soft, so the holes can be damaged easily.
2. Warping of the shelves:
If the shelves are not properly aligned or are pressed too tightly between the side panels, this can cause warped or crooked shelves. This is especially a problem with older Billy units when reassembling.
3. Back panel issues:
A back panel that is installed incorrectly and does not use all fixing points can lead to instability and may cause cracks quickly.
4. Over-tightening screws:
Over-tightening screws is a common cause of loose joints. The threads in particleboard give way quickly.
An important question: How exactly do you proceed during the assembly? Are you using the original instructions and all parts correctly?
Ellie63
25 Jul 2024 09:45
Filippo schrieb:
An important question: How exactly do you approach the assembly? Do you use the original instructions and all the correct parts?
Thank you for your detailed response, Filippo! I am indeed referring to the original IKEA instructions and I follow them carefully. However, during the last assembly, I felt that tightening the screws requires a lot of finesse. You are right, the particleboard seems quite delicate.
Is there a technique for tightening screws that can help avoid applying too much torque? For example, should some screws be tightened only by hand while others are tightened more firmly?
Dilen
25 Jul 2024 10:18
Hello Ellie63,
to answer your question, I recommend a systematic approach when tightening screws:
First, you should tighten all screws just by hand to properly align the parts. This way, there is no damage to the particleboard. Then, do a second round where you carefully tighten the screws a bit more – but never apply maximum force.
Especially with Billy, the dowels and screws are designed so they cannot withstand constant maximum force. Excessive tightening quickly leads to pull-outs. I also recommend not using a high-powered cordless drill, but rather a manual screwdriver or a drill driver with a torque limiter.
Do you have any screws that are particularly prone to issues? Usually, these are the ones on the side panels, which need to support the shelf later on.
SETHBLA
25 Jul 2024 10:57
I can only agree with Dilen. Especially important: avoid applying excessive force. Always screw in carefully, otherwise the board will be damaged immediately.
