ᐅ How can I extend the lifespan of BILLY shelves?
Created on: 7 Mar 2015 09:12
keoro
I own several BILLY shelves from IKEA and want to significantly extend their lifespan. My question is: What methods or maintenance tips would you recommend to keep BILLY shelves stable and visually appealing for many years? I am especially interested in load-related factors, environmental influences, measures to prevent warping, and whether it makes sense to treat the material in any other way.
Are there any experiences regarding the best way to secure the shelf joints and whether it is advisable to reinforce screws or connection points afterward?
Thank you in advance for your insights and tips!
keoro
7 Mar 2015 13:35
emmaju schrieb:
Have you already secured your shelves to the wall? If not, please do so
Yes, all my Billy shelves are attached to the wall using the included wall fasteners. They are satisfactorily stable, but I wonder if there are better or additional solutions, especially for tall, fully loaded shelves.
reoWilhelm schrieb:
Small rubber pads under the feet to prevent moisture from the floor from affecting the bottom of the shelves directly
That’s an interesting, practical tip I hadn’t considered before. Does anyone use this, and how do you best attach such pads?
Also on the topic of reinforcing shelf boards with central supports: Are there any experiences with removing the boards and replacing them with strengthened ones – in case the shelf needs to carry very heavy loads?
Shawn38
7 Mar 2015 14:16
I can only agree with the previous advice and would like to add that the quality of the back panel in BILLY shelves is a crucial factor for stability. The standard back panel is thin and made of particleboard or thin hardboard.
If you value longer durability, you should consider replacing the back panel with a thicker, more robust board (e.g., 3-4 mm (0.1-0.2 inches) plywood or MDF). This can be cut to size, and it greatly improves lateral stability.
When fully loaded, this reduces twisting and provides significantly more support.
The back panel is often underestimated, yet it acts like a stiffening element, similar to a reinforcing triangle in structural engineering.
Has anyone here already tried this?
Brian
7 Mar 2015 14:47
Shawn38 schrieb:
If you want longer durability, you should consider replacing the back panel with a stronger, more stable board (e.g., 3-4 mm (0.1-0.15 inch) plywood or MDF).
I can fully confirm that!
I have also reinforced my BILLY shelves with stronger back panels and additionally screwed angles/brackets on the sides. This prevents any breaking or warping, even when fully loaded.
Attaching such brackets is not difficult at all and reduces the risk of the shelf becoming distorted over time. Especially if you want to use the shelf for a long time, this effort is worthwhile.
Noahlu
7 Mar 2015 16:25
Here is an additional important point that is often underestimated: temperature and humidity fluctuations. BILLY shelves are made from wood-based panels that react to swelling and shrinking, so they should ideally not be exposed to constant changes in moisture.
Indoor humidity should be kept as consistent as possible, ideally between 40 and 60%.
Another tip: when assembling, make sure none of the supplied parts are installed under tension. A warped shelf often does not return to its original shape.
Regularly checking the condition of the screws is also helpful: screws loosen over time due to slight movements and, if neglected, can cause wobbling or even failure. Tightening them is therefore essential.
I have also had good experience with a protective polyurethane or varnish coating on exposed edges to prevent swelling caused by moisture.
leebi7
7 Mar 2015 18:01
noahlu schrieb:
Regular retightening of screws is mandatory
Exactly!
I would even recommend systematically checking all connections every 6 to 12 months, especially for heavily loaded shelves. Additionally, you can use small washers at critical points to improve fixation, which helps distribute the clamping force more evenly and protects the material.
Shawn38 schrieb:
Replace the back panel with a stronger, more stable board
That is definitely one of the best measures to improve lateral stability. For large BILLY units with multiple sections, it might also be worthwhile to link the modules together using internal connectors, creating a single system that is less prone to twisting.
What kind of long-term load are you aiming for? And do you already have shelves showing signs of damage?
keoro
8 Mar 2015 08:12
leebi7 schrieb:
What long-term load are you aiming for? And do you already have shelves that show signs of damage?
Thanks for asking! I will mainly use the shelves for books, so I want to make the best use of the load capacity. At the moment, I don’t see any visible damage; only occasionally the middle of a shelf board sags slightly when I place a lot of books on it.
The load varies, but I want to be able to support at least 15–20 kg (33–44 lbs) per shelf sustainably.
What would you recommend for spacers or additional shelf supports as a middle brace? How does installation work if you want to add a center support later? Do you have to drill or is there a way to clamp something in?
Another idea is installing metal brackets, but I’m not sure if that would look good. Does anyone have tips on this?
