ᐅ Which cleaning methods cause the least damage to BILLY shelves?
Created on: 16 Apr 2020 08:27
POTORON
Hello everyone, I have a specific question as I am currently considering the best way to clean my IKEA Billy shelves without damaging them. There are various cleaning products and methods, but it would be very helpful to know which cleaning techniques and products are actually the gentlest for the MDF-like surface used in Billy. Also, how to best remove stains and whether aggressive cleaners or high moisture should generally be avoided. Does anyone have experience with methods that work well while protecting the material and finish? Please feel free to explain why and share common mistakes to avoid.
Tevin
17 Apr 2020 07:34
Hello everyone, since the cleaning of BILLY shelves is being discussed here, I would like to add that the type of use also plays a role.
Shelves in the kitchen or workshop often require more heavy-duty cleaning, but when it comes to BILLY, you should avoid aggressive cleaners such as ammonia or strongly alkaline products, as they damage the surface.
For very dirty spots, it can sometimes help to use damp cleaning wipes specifically made for furniture. These are pH-neutral and prevent scratches.
For those who want to be absolutely sure, it is best to use microfiber cloths, lukewarm water, and if necessary, a few drops of dishwashing liquid. Important: Never scrub the surface or let a lot of moisture sit on it.
Do you have the shelf in a place with high humidity? Then it’s better to wipe it dry more often to avoid mold or moisture damage.
faso31
17 Apr 2020 09:01
kla69 schrieb:
The gentlest way to clean such surfaces is with a slightly damp, lint-free cloth. It is important that the cloth is only barely moist, as too much moisture can cause particleboard edges to swell or permanently damage the board by harming the laminate.
That may be true, but I think the general caution about water with melamine-coated furniture is somewhat exaggerated. The laminates are quite durable nowadays, and if you work quickly, nothing will happen.
What I do find critical, however, is the use of aggressive cleaning agents—I fully agree with kla69 on that.
My question to the group: Are there any reliable long-term experiences with mild cleaners and their effects on the appearance? Many manufacturers provide guidelines, but how does this play out in everyday use? Has anyone here been able to compare shelves after several years using different cleaning methods?
danial60
17 Apr 2020 11:26
faso31 schrieb:
The films have become quite durable by now, and if you work quickly, nothing will happen.
I can partially agree with that.
From my experience: The issue is less about short-term exposure to water and more about the cumulative effect of moisture and cleaning agents over months and years. Especially with inexpensive furniture like BILLY, you can see discoloration along the edges or slightly swollen spots in the long run.
A methodical and safe approach is therefore to clean as dry as possible or follow a clearly defined cleaning cycle using mild cleaners and quick drying.
Regarding material compatibility: Make sure the cleaner does not contain solvents or aggressive surfactants. Use soft microfiber cloths rather than sponges with pores or abrasive surfaces.
I also find the tip to occasionally apply furniture polish for melamine-coated surfaces interesting – it provides a kind of protective film and maintains the shine; however, it works better with higher-quality films than with BILLY.
kla69
17 Apr 2020 14:53
faso31 schrieb:
Are there really reliable long-term experiences with mild cleaning agents and their effect on the appearance?
Good question, which I am happy to address: indeed, there is some long-term experience from the furniture industry.
Melamine-coated surfaces, like those on BILLY, are durable but not indestructible.
Over several years, regular cleaning with mild soaps actually leads to minimal wear on the surface, usually visible as slight dulling or minor scratches.
On the other hand, household cleaners containing ammonia, citric acid, or other harsh additives can damage the laminate and permanently alter its appearance.
So yes, gentle cleaning has a positive long-term effect, while aggressive cleaning agents will ruin the surface more quickly.
Mechanical care is also important: avoid scrubbing with abrasive cloths or sponges.
I also recommend maintaining the surfaces by occasionally wiping them with a furniture care product suitable for MDF or melamine-coated furniture.
@POTORON: Do you have specific areas on the shelving unit that are more heavily soiled, or is this about regular general cleaning?
POTORON
17 Apr 2020 16:15
Thank you for the detailed responses so far. I especially appreciate the advice regarding moisture and the warnings about harsh agents.
Regarding your question kla69: This mostly concerns routine cleaning done daily to weekly, but also occasional stubborn spots, for example on office shelves that sometimes get light dust or ink stains from pens lying around.
This means I am looking for a safe basic cleaning method that I can use regularly, plus guidance on how to tackle persistent stains selectively.
Your tips on microfiber cloths and mild soapy water sound good.
May I also ask about the usefulness of furniture polish? Is it advisable to apply it after cleaning, or is that more of a myth when it comes to melamine-coated BILLY shelves?
Liduta
18 Apr 2020 08:03
POTORON schrieb:
May I ask about the relevance of furniture polish? Does it make sense to apply it after cleaning, or is this more of a myth in the context of melamine-coated BILLY shelves?
Good question!
Furniture polish on melamine-coated furniture is not always necessary. It can temporarily enhance the appearance and hide minor scratches by creating a thin protective layer.
However, there are two points to consider:
1. Some polishes contain wax or silicones that can build up on the surface over time. This often makes the furniture more prone to dust accumulation.
2. The polish may cause discoloration on light-colored melamine, especially if it is oily.
My advice: If you want the effect, use a pH-neutral polish specifically designed for melamine and apply it sparingly and infrequently, for example, once every three months.
Otherwise, regular cleaning with mild cleaners and prompt drying is sufficient.
This way, the BILLY shelf will stay in good condition for a long time.
