ᐅ Make Ikea Metod Drawers Quieter and Smoother with a Simple DIY Trick
Created on: 2 Nov 2024 08:37
Fevedat67
Fevedat67
2 Nov 2024 08:37
Hello everyone, I have a specific question regarding the Ikea Metod kitchen or furniture drawers. As many may know, the drawers from the Metod series are functional, but they often feel somewhat noisy and jerky when closing. I am therefore looking for a simple, practical DIY trick to improve this issue—making the drawers quieter and smoother without having to install expensive dampers.
I am especially interested in whether anyone has experience with a straightforward modification that smooths the mechanical movement while requiring minimal effort and materials. Any advice or tips on suitable materials or small adjustments that have a lasting effect are also welcome. Are there perhaps any insider tips that are not widely known? Thank you very much for your ideas!
dijan
2 Nov 2024 09:11
Fevedat67 schrieb:
I am looking for a simple, practical DIY trick to improve exactly this problem – that is, making the drawers quieter and smoother without having to install expensive dampers.
Haha, I had exactly the same problem last year! My little tip: just apply self-adhesive felt strips to the inner edges of the drawers. They surprisingly absorb the impact well and are so inexpensive that it's definitely worth trying out.
Another advantage: the drawer often slides more smoothly because the felt acts like a kind of buffer.
A little bonus insider tip: for stability and smoother sliding, don't load the drawer slides fully at first. Sometimes less is more. 😉
Dilen
2 Nov 2024 12:42
I would like to explain the mechanics of the Metod drawers in more detail, as understanding them helps when choosing a DIY solution.
Basically, the drawers are equipped with full-extension slides that run on metal rails, with a plastic runner often located at the contact point. This plastic runner ensures smooth movement but can cause hard contact and noise without additional treatment.
In my experience, the following DIY trick works best:
- Spray the plastic runners with some silicone spray or a special plastic lubricant. This reduces friction and makes closing noticeably smoother.
- For quieter closing, self-adhesive damping pads made of foam rubber or felt work well, applied directly to the back wall of the drawer or the inner frame of the cabinet.
- Another option if you want to get creative: attach a thin strip of pipe insulation (material: closed-cell foam) to the inner wall. This helps reduce the impact noise.
Important: With all measures, pay attention to precise installation to ensure the drawer still runs smoothly without sticking or warping.
Are you experiencing noises when closing the drawer or rather noticeable jerking? This can affect the approach.
Paunon
3 Nov 2024 07:51
Glue felt strips to the edge, lightly lubricate the runners, and avoid overfilling the drawers. This is usually enough to make the Metod drawers operate more quietly.
warrenka57
3 Nov 2024 15:33
Dilen schrieb:
Are you already hearing noises when closing, or is it more of a noticeable jerk?
I want to add to that while agreeing. In my case, it was actually a combination of both: at first, the drawers closed loudly with a bang, but after a while, they also started to slightly slip out of their tracks on the sides, which caused the jerking.
I then tried your tips, Dilen, and additionally completely removed, cleaned, and reinstalled the slides – that significantly reduced the jerking. The drawer dampers are actually good, but when dirt or misalignment get involved, it really affects the comfort.
You shouldn’t underestimate how quickly these small issues can become annoying in everyday use – but there is hope with proper maintenance and a bit of DIY care!
