ᐅ Lighting in the garage, including the workshop area
Created on: 6 Feb 2019 16:49
denz.
I’ve attached a section of the garage including the workshop area.
2D floor plan with dimensions and room layout of an interior space
For lighting, the original plan was to use the seven large yellow rectangles shown. These were intended to be LED panels, possibly 40x40cm (16x16 inches), but I hadn’t finalized the size yet.
I have now marked the garage door and the attic hatch in orange. The number 20 (20cm / 8 inches) next to the garage door indicates that when the door is open, it only extends to the first orange line, and 20cm (8 inches) further is the profile frame of the guide rails. The motor is located directly beneath the central panel. That means this middle light doesn’t really make sense anymore. I’m wondering whether to simply remove it and keep the rest as planned, or if I should rethink the entire layout.
For example, I’ve noticed that in the workshop area where the workbench is supposed to go (top left on the plan in front of the window), I might need more light.
The room could also be used for a birthday party in winter, so the lighting shouldn’t be just a bit of dim, insufficient light.
How have you solved this?
kkk272729
7 Feb 2019 14:52
I have two rows of three evenly spaced.
I have excluded the area for the open garage door.
In what situation is the garage door open and the light on?
Perhaps only at the moment when you are driving in?
O
Obstlerbaum
7 Feb 2019 17:32
Without labeling LED as a buzzword... I wouldn’t use any LEDs at all... ahem...
They’re not on all the time, they’re not the best... why not simply try halogen? 🙂
It’s not that I don’t have LEDs, but halogen is just more comfortable for work lighting.
Why should light from halogen lamps be more comfortable?
7 Feb 2019 23:02
Obstlerbaum schrieb:
Why should light from halogen lamps be more pleasant?
In short: because halogen light is generally more comfortable for people.
LED produces a bluish light (excluding colored effect lights, as this is about primary or work lighting), even if this is not always consciously noticed. Just try searching online for LED versus halogen.
O
Obstlerbaum
8 Feb 2019 14:41
In short: halogen always provides a more pleasant light for people.
LED light has a bluish tint (excluding colored effect lights, since we’re talking about main or task lighting here), even if it’s not immediately noticeable. Just try googling: LED or halogen.
I agree that there are also poor-quality LED bulbs on the market, but otherwise I mostly hear a lot of misleading information. Not everything you read on the internet is accurate...
9 Feb 2019 00:34
Otherwise, I mostly hear a lot of dangerous half-knowledge. Not everything you read on the internet is true...
And that’s exactly why you shouldn’t overestimate LED just because it’s widely praised.
LED is not an all-round solution, nor is it suitable as task lighting.
It is an accent light that offers the advantages of not heating up and having low power consumption.
O
Obstlerbaum
9 Feb 2019 20:07
And that’s exactly why LED lighting shouldn’t be overrated just because it’s widely promoted. LED is not an all-round solution, nor is it suitable as task lighting. It’s an accent light that has the advantage of not heating up and consuming little energy.
I’m not sure what leads you to this opinion, but with proper light bulbs or fixtures there’s nothing to worry about. There are already very high-quality models available from around 10 EUR for various sockets...
