ᐅ Last chance to consider electrical provisions – ideas and tips
Created on: 15 Oct 2020 14:16
Piotr1981
The preliminary work (chasing/chiseling, etc.) for the electrical installation has started, for now only inside the house.
I still have the opportunity to consider "important" things and/or extras and would like to get tips, ideas, or suggestions from you.
What is already planned:
- Sufficient electrical outlets (in every corner)
- Duplex LAN Cat.7 and satellite connections in every room (except, of course, bathrooms, utility rooms, etc.)
- Connections for access points on both ground floor and upper floor
- Switches and room thermostats
- Preparation for electric roller shutters
I’m only looking for ideas, not exact placement.
Maybe you have some great suggestions to share.
Thanks...
Thanks...
Piotr198116 Oct 2020 09:19I am truly very grateful to you all for the many great contributions and tips. The forum has been a huge support to me in many ways so far. Thank you for that.
Piotr1981 schrieb:
Shading control is managed via a weather station.
I really struggle with decorative lighting. Window recesses are actually nice – but somehow also outdated.
I have planned floor sockets in two prominent spots where decoration or a Christmas tree might go. Where will the weather station be installed?
If you have a satellite dish on the roof,
you could use a longer mast and install the weather station above the dish and the roof ridge. That way, you get fairly accurate measurements.
That’s how I will mount my rain and wind sensors this weekend.
The rain sensor is for irrigation, and the wind sensor controls the venetian blinds.
hanse987 schrieb:
Where will the network cabinet be located? If it’s going into the utility room anyway, you can also run a surface-mounted cable to the heating system there. You should also consider the size and position of the network cabinet.
A topic that has come up more often recently is the outdoor access point for the terrace and garden. An access point for the terrace is definitely a good idea.
I have already run a duplex cable to the terrace. So the access point will later be installed in the corner of the terrace area, under the awning.
HarvSpec schrieb:
- Cat.7 at the front door and potential indoor intercom station
- Cat.7 for access pointsBy front door, you probably mean outside, I assume. Is there a recommended height for that?
Piotr198116 Oct 2020 21:01Hausbaer schrieb:
You probably mean the front door from the outside, I assume. Is there a recommended good height for that?The mailbox system including the Doorbird is installed at a rough floor height of 1.70 meters (5 ft 7 in), which corresponds to a finished floor height of 1.50 meters (4 ft 11 in). The camera is then approximately at a height of about 1.45 meters (4 ft 9 in).
This is the height that was recommended to us.
Piotr1981 schrieb:
The mailbox system including the Doorbird will be installed at a rough floor height of 1.70 meters (5 ft 7 in), so the finished floor height is 1.50 meters (4 ft 11 in). The camera will then be at about 1.45 meters (4 ft 9 in).
This is the height that was recommended to us.Yes, that fits. Our door viewer was also planned for a similar height.
