ᐅ Last chance to consider electrical provisions – ideas and tips
Created on: 15 Oct 2020 14:16
Piotr1981
The preliminary work (chasing/chiseling, etc.) for the electrical installation has started, for now only inside the house.
I still have the opportunity to consider "important" things and/or extras and would like to get tips, ideas, or suggestions from you.
What is already planned:
- Sufficient electrical outlets (in every corner)
- Duplex LAN Cat.7 and satellite connections in every room (except, of course, bathrooms, utility rooms, etc.)
- Connections for access points on both ground floor and upper floor
- Switches and room thermostats
- Preparation for electric roller shutters
I’m only looking for ideas, not exact placement.
Maybe you have some great suggestions to share.
Thanks...
AMNE3IA18 Oct 2020 22:07
To prevent the wall lamps from causing glare, they should be positioned at eye level. However, to us, that seemed too low. Therefore, we chose a height of 1.8 m (6 feet).
Piotr1981
18 Oct 2020 23:54
However, we felt that was too low.
That’s why we chose a height of 1.8 m (5 ft 11 in).
Our lighting designer said something similar. So I can confirm this. Generally, the height is between 1.80 and 1.95 m (5 ft 11 in and 6 ft 5 in), depending on the lamp and the ceiling height.
Piotr1981
18 Oct 2020 23:58
AMNE3IA schrieb:
Where should the weather station be installed?
If you have a dish antenna on the roof,
you could use a longer mast and install the weather station above the dish and the roof ridge. That way, you get fairly accurate measurements.
This weekend, I will mount my rain and wind sensor like that.
Rain sensor for irrigation and wind sensor for controlling the external blinds.
Having an access point for the terrace is definitely a good idea.
I ran a duplex cable to the terrace. So later it will be installed in the corner of the terrace area under the awning.
An exact position for the weather station has not been discussed yet. Where would you place it?
If needed, I would attach the dish to the facade instead of the roof. The reason is that I am planning to install a photovoltaic system in 2021. In theory, I could put it directly on the ridge, but that probably wouldn’t look very good, right?
What about an outdoor access point? Exposure to moisture? Cold? Are there any experiences with that?
Piotr1981
19 Oct 2020 00:00
AMNE3IA schrieb:
Attic/Roof;
- Solar cables
- Lightning protection cable 10mm² (10.76 AWG)
- Cat cable for video surveillance
- Cables for weather station/wind and rain sensors
Interior;
- Cables for infrared heating
- Cables for electric toilet
- Cables for bathtub with whirlpool function
- Cables for toilet odor extraction
- Audio cables for built-in speakers
- Home theater preparation
- Cables for central control of Venetian blinds or roller shutters
- Picture lighting
- Staircase lighting
- Niche lighting in shower area
- Lighting under kitchen island
- Cable ducts inside walls in case a TV is mounted
- Additional workspace lighting
Exterior;
- Cables for motion detectors and outdoor lighting
- Fence lighting
- Possibly extra lighting above the patio table
- Cables for electric grill
What exactly did you mean by the lightning protection cable? Not the one connected to the foundation earthing, right? Maybe I’m mixing something up.
hanse987
19 Oct 2020 00:31
Piotr1981 schrieb:
How about using an access point outdoors? Moisture? Cold? Are there any experiences?
The access point must be rated for outdoor use. For example, Unifi offers the Flex HD.
Piotr1981
19 Oct 2020 00:35
hanse987 schrieb:
The access point must be suitable for outdoor use. For example, Unifi offers the Flex HD.
Thanks a lot. The electrician seems to want to push a FRITZ!Box on me, one for the ground floor and one for the upper floor. Is that a good idea? Or is it better to go with the Unifi units?
