ᐅ Which router works best with Ubiquiti devices?
Created on: 1 Aug 2020 10:12
Ötzi Ötztaler
Ötzi Ötztaler
1 Aug 2020 10:12
I am currently in the process of selecting and purchasing network devices. For Wi-Fi, it will probably be the UAP-AC-PRO (one per floor), unless the Ubiquiti Wi-Fi 6 access point is released in time. Side question: Would it be worth waiting and using an older interim device until Wi-Fi 6 is available? From what I understand, Wi-Fi 6 mainly offers advantages with many simultaneous users, which is rather uncommon in a single-family home.
The PoE switch will likely also be from Ubiquiti, a 16-port model with 150W. Alternatively, it could be Netgear. VLAN might be useful to separate some devices cleanly from the network, but it’s not absolutely necessary.
For the video door intercom system, I am still considering 2N, Doorbird, and Gira (see another thread—I haven’t decided yet).
Now the question: I have read mixed reviews about the USG “router.” Would it be better here to use a FritzBox with Wi-Fi disabled? Or what would you recommend? The FritzBox has the advantage that you can also connect landline phones directly through it. Which other providers besides FritzBox are recommended here? The Wi-Fi performance of the router does not matter; it’s about convenience and many nice features. It doesn’t need to be semi-professional. QoS features for stable IP-TV streaming while the kids do large downloads would also be advantageous.
Thanks in advance!
rick20181 Aug 2020 10:36
Better to use the Nano HD or Flex HD as an access point. They are more modern, faster, have longer support, and consume less power.
You could use the Dream Machine as a router. It saves you from needing an access point.
New USGs will probably be released soon.
We are using USG, USG Pro, and in my new house the USG XG. We haven’t had any problems. With the USG, you can take advantage of all the benefits.
Ötzi Ötztaler
1 Aug 2020 12:06
Thanks for the tip about the Nano HD! I’ll go with that then.
So the USG isn’t actually a bad choice as a router? Maybe I’ll start with an old, cheap unit and then buy the successor to the USG. Or just get the current USG right away.
What advantages does a pure Ubiquiti solution offer?
How would you handle WLAN landline phones in that case?
The Dream Machine as a router is a good suggestion, but I really don’t need an additional Wi-Fi transmitter in the utility room, and on each floor there is already a central wall outlet planned for a well-visible UniFi access point. It’s a status symbol and all.
ntsa86
1 Aug 2020 12:08
I also have 2 AC Pros and the USG. On the WAN side, there is only a Gigacube LTE router connected. It does nothing else but provide internet.
Ötzi Ötztaler
1 Aug 2020 12:09
One more question, is the cloud key important if you don't have a server running 24/7? Or is it more of a "nice to have"?
ntsa86
1 Aug 2020 12:59
The CloudKey is wonky. The UniFi Controller running on it manages your access points centrally. If you want a USG and CloudKey, it's better to consider the Dream Machine, which includes both.
