ᐅ Kitchen base cabinet, 25 cm (approximately 10 inches) deep.
Created on: 27 Jul 2015 13:23
Tux
Tux
27 Jul 2015 13:23
Hi,
I have a U-shaped kitchen.
The shorter side of the U is about 120cm (47 inches) wide (clear dimension from cabinet to cabinet is 120cm (47 inches), and from handle to handle is 114cm (45 inches)) and only has a countertop.
In this area, there is also a radiator and the kitchen window.
I would now like to install base cabinets in this section as well. NOT METOD due to cabinet height of 70 or 71cm (28 or 28 inches).
I was rather thinking of Faktum instead.
Another issue is that I only have 30cm (12 inches) of space from the radiator. So I would need base cabinets with a drawer or similar that are only 25cm (10 inches) deep.
Does anyone have any ideas on what could be done here?
IKEA-Experte
27 Jul 2015 22:00
you could shorten a 35 cm (14 inch) deep Faktum carcass in depth, install undermount slides, and build drawers for it.
Tux
28 Jul 2015 06:33
Thank you for your reply.
Are there such guides for the dimension?
Do you mean 35cm (14 inches) wall cabinets? I haven't found base cabinets with a depth of 35cm (14 inches).
Regards
IKEA-Experte
28 Jul 2015 11:29
With FAKTUM, the wall cabinets were also used as base cabinets.
The Blum Tandem under-mount slides are available with a nominal length of 250 mm (10 inches) and require a minimum cabinet depth of 253 mm (10 inches). If you want them to be like the Maximera drawers, then the Tandembox Antaro would be the option with a minimum nominal length of 270 mm (11 inches) and a minimum available cabinet depth of 273 mm (11 inches).
Tux
28 Jul 2015 12:05
Ok. Thanks for the tips.
I’ll see if I can manage that 😀
Regards
phobos
