ᐅ KALLAX doors slam against the baseboard – any ideas for reducing the impact?
Created on: 3 Aug 2024 09:17
Letipa
I have a problem with my KALLAX doors from IKEA: every time I close them, they bang against the baseboard, which is quite unpleasant and could eventually cause damage. The furniture is standing on a hardwood floor, and the baseboard is a standard wooden skirting board that cannot be modified.
I am mainly interested in how to effectively decouple the door from the baseboard without major alterations or having to lift the furniture completely off the floor.
Do you have any ideas or experience with elastic dampers, spacers, or special materials that can be discreetly installed? How can the banging be prevented while maintaining the functionality of the doors?
I look forward to tips and practical solutions, including recommendations for materials or installation advice!
In summary, various solutions prove to be most effective:
1. Adjusting the door hinges to prevent physical contact.
2. Installing dampers such as self-adhesive felt, rubber, or silicone pads that create a soft barrier between the door and the baseboard.
3. Using furniture feet with integrated rubber buffers to increase floor clearance, if possible.
When using adhesive pads, pay special attention to a clean surface and the appropriate material thickness—typically 2-5 mm (0.08-0.2 inches)—for optimal cushioning without affecting the appearance or functionality of the doors.
All recommended materials are available at hardware stores or online, with silicone pads being particularly preferred due to their elasticity and durability.
Important: Combining hinge adjustments with cushioning extends the lifespan of the furniture and ensures a significantly more comfortable use.
I also recommend testing different types of materials before the final installation to find the best solution for the individual situation.
