ᐅ KALLAX doors slam against the baseboard – any ideas for reducing the impact?
Created on: 3 Aug 2024 09:17
Letipa
Letipa
3 Aug 2024 09:17
I have a problem with my KALLAX doors from IKEA: every time I close them, they bang against the baseboard, which is quite unpleasant and could eventually cause damage. The furniture is standing on a hardwood floor, and the baseboard is a standard wooden skirting board that cannot be modified.
I am mainly interested in how to effectively decouple the door from the baseboard without major alterations or having to lift the furniture completely off the floor.
Do you have any ideas or experience with elastic dampers, spacers, or special materials that can be discreetly installed? How can the banging be prevented while maintaining the functionality of the doors?
I look forward to tips and practical solutions, including recommendations for materials or installation advice!
Filippo
3 Aug 2024 10:05
Letipa schrieb:
I’m especially interested in how to effectively decouple the door from the baseboard without major renovations or having to completely lift the furniture off the floor.
That’s a pretty smart approach, tackling the problem right at the source without turning everything upside down.
My recommendation would be to use polymer dampers or rubber buffers that can be attached directly to the inside of the doors. It’s very important to choose the right hardness – too hard won’t absorb impact, too soft will quickly wear down.
A second step is to check whether the doors are properly aligned flush – sometimes small hinge adjustments can prevent contact with the baseboard. You can measure this with a gap gauge.
Would it be possible to slightly raise the feet on the KALLAX? There are also special furniture feet with rubber buffers that work well for decoupling.
Also: what’s the condition of the baseboard? Is it painted or raw? Sometimes adding a narrow strip of self-adhesive felt to the baseboard can already help.
Finally: how loud is the noise? Does it only happen at certain angles? Limiting the door opening to specific angles with a door stop can also provide relief.
What do you think of these solutions? Are there any special features of your furniture that I should know about?
dijan
3 Aug 2024 10:18
Hi Letipa!
That problem sounds really annoying, especially when the doors keep slamming shut :-)
I once solved something similar on a cabinet using small rubber bumpers that you simply stick inside the door—they are very discreet and work well as "airbags" between the door and the baseboard.
Alternatively, you can try sticking a thin felt strip onto the baseboard. This cushions the impact, is quick to do, and reversible.
You don’t want the door to end up squeaking like a rubber duck, but usually, this works pretty well without any annoying side effects.
Hope this helps you! 🙂
Palenar
3 Aug 2024 11:48
This is a crucial point.
I recommend first measuring the gap between the door and the baseboard when closed, both on the left and right side, using a protractor and a ruler. Be sure to watch for any warping of the door caused by uneven floors or misaligned hardware.
If slight hinge adjustments are possible, the door can be tilted so that it hovers just above the baseboard. Since the door weight is usually low, a clearance of just 1–2 millimeters (0.04–0.08 inches) is sufficient.
If this is not enough, cushioning measures at the impact point are advisable.
Polyurethane foam or silicone pads are recommended because they are flexible and durable. Caution: When using silicone-based seals, corrosion-resistant adhesives should be used to avoid stains on the painted KALLAX.
Another option is a self-adhesive, thin foam rubber profile, similar to those used in door seals. The advantages are easy cutting, mechanical durability, and quiet contact.
I am curious: Is the furniture secured to a wall? Sometimes wall stops or bumpers attached directly to the cabinet help limit the door movement.
Letipa
3 Aug 2024 13:02
Palenar schrieb:
I’m curious: Is the piece of furniture fixed to a wall?
Thanks for the detailed explanations. The door adjustment and different dampers sound promising.
The KALLAX actually stands freely in the room, so it’s not attached to the wall.
I recently noticed that the doors are slightly sagging downward—probably due to the hinges or because they have been shifted at some point. I could lift or adjust them, but I want to avoid screwing too much into the structure to not risk voiding the warranty.
The baseboard is smoothly painted and has a softer wood surface, which might also contribute to the slamming sound, as the tone reverberates.
Has anyone had experience with self-adhesive felt strips or rubber bumpers that can be applied discreetly? What thickness would be ideal to provide enough cushioning without being bulky?
TEOZAR
4 Aug 2024 08:37
Hello Letipa and everyone,
If you want to avoid making major changes to the furniture structure or doors, adhesive bumpers or felt strips are actually some of the simplest solutions.
In my experience, felt strips with a thickness of 2-3 mm (0.08-0.12 inches) work very well. They cushion impacts and do not leave permanent marks, which can be important in rental apartments or with new furniture.
Additionally, you can use rubber or silicone bumpers, which are sold as furniture protectors in hardware stores. These typically have a height of 3-5 mm (0.12-0.20 inches) and come with a strong adhesive.
One important tip: Clean the adhesive surface thoroughly with alcohol before applying so that the adhesive sticks properly and the bumper does not come loose.
If the doors only slightly touch the baseboard, a combination of felt and rubber bumpers could significantly reduce noise and soften the impact.
Maybe a small self-adhesive pad on the inside of the door could also help? Placed where the door meets the floor, this works as a cushion as well.
I hope these practical tips help you.
