ᐅ KALLAX Damaged During Transport – What to Claim?
Created on: 23 Dec 2022 14:27
Bjornke
Bjornke
23 Dec 2022 14:27
A few days ago, I received my KALLAX shelf from IKEA. Unfortunately, the packaging was visibly damaged, and when unpacking, I noticed several cracks and dents in the wood. My question is: What exactly should I claim in a situation like this, and how should I proceed? Should I report the damage immediately to the delivery service or contact IKEA directly? Also, how detailed does the damage description and documentation need to be for a successful claim?
I would really appreciate concrete advice on the best way to handle this, as I’m not sure what my rights are in such cases and how to protect myself properly. Thanks in advance!
Peose
23 Dec 2022 15:04
Hey Bjornke!
Oh no, that’s really frustrating, but don’t worry! 🙂 With large furniture like KALLAX, this can happen sometimes. The important thing is to take photos immediately, making sure to capture detailed shots of all damages and the packaging. Then notify the shipping company in writing right away, preferably by email, so you have proof!
At the same time, contact IKEA and explain the situation – they are usually very accommodating in cases like this.
It sounds complicated, but it usually gets resolved quickly if you document everything well! You can do it! 🙂
TEBILO
23 Dec 2022 16:18
Hello Bjornke,
I can address the issue from a technical perspective in more detail. If the packaging is already visibly damaged on the outside, this indicates that the damage likely occurred during transport. It is important that the damage is documented immediately upon receipt of the goods and noted in the delivery report, if available.
I recommend the following steps:
1. Take photos: Capture both the packaging (damages, labels) and the damaged areas on the KALLAX precisely.
2. Contact the carrier and report the damage immediately. Be sure to observe the acceptance conditions, as there are often deadlines for reporting damages.
3. Next, inform IKEA—through customer service and also by email—providing a description of the damage along with the photos.
4. Make a claim: depending on the damage, you can request either a repair (replacement delivery of the damaged parts) or a full refund/return.
5. Important: Keep all documents, including purchase receipts and correspondence.
How severe is the damage exactly? Are there only superficial scratches, or are there structural damages?
Bjornke
23 Dec 2022 16:57
TEBILO schrieb:
How severe is the damage exactly? Just surface scratches or actual structural damage?
Hello TEBILO,
thank you for the detailed response! There are actually several cracks in the cabinet area, and some of the wooden panels are chipped. You could say the stability is compromised, not just a minor blemish. What makes me uncertain is whether it’s really worth insisting on a replacement or if I should be satisfied with a goodwill settlement, assuming IKEA even offers something like that?
Gino38
23 Dec 2022 18:02
Bjornke schrieb:
There are actually several cracks on the carcass area, and some of the wood panels are partially splintered.
Such damage is definitely not minor and falls under the warranty for defects. You are basically entitled to repair or replacement if the item arrives damaged.
I would recommend contacting Ikea immediately in writing with photos, clearly pointing out the defects. If Ikea refuses to cooperate, it often helps to insist on your right of withdrawal or your legal warranty rights.
As TEBILO already mentioned, documenting the damage upon receipt and reporting it as soon as possible is very important.
Peose
24 Dec 2022 09:47
Gino38 schrieb:
You are generally entitled to repair or replacement
Exactly! And if you’re unlucky, there might be delays – but don’t give up! 🙂 IKEA often has solutions ready and doesn’t want unhappy customers.
I once had a damaged cabinet, and they offered me a voucher, which was fine for me. It somewhat depends on the extent of the damage and how well you get along with customer service.
Important: Don’t let yourself be pressured, it’s your right! Good luck!
