ᐅ Kallax damaged after spilled drink – help!
Created on: 16 Oct 2021 09:12
nonfalk50
nonfalk50
16 Oct 2021 09:12
I have the following problem: a drink was spilled on my Ikea Kallax shelf—specifically, a large amount of water mixed with fruit juice. Unfortunately, the liquid didn’t just spread on the surface but apparently soaked into the material. Now, the back panel at the bottom shelf is swollen in several places, and the edges are crumbling, or rather, the particleboard coating is flaking off. I’m not sure how to best proceed here.
Is it possible to fix this somehow, or do I need to replace the entire back panel? If so, does anyone have tips on where to get a suitable back panel cheaply and how to replace it yourself?
I’m also interested to know if there’s any product that can help stabilize the surface again or at least prevent further swelling.
Thank you in advance for your ideas and help!
sarGabriel
16 Oct 2021 10:45
Hi,
if the back panel has swollen, the only solution is to replace it. Try to keep the area dry, otherwise it will get worse. Replacement back panels can often be ordered from Ikea as spare parts or you can get similar wood at a hardware store.
Kinbu
16 Oct 2021 11:33
sarGabriel schrieb:
If the back panel is swollen, the only solution is to replace it.
I agree with that. When particleboard swells significantly due to water, it loses its stability. You can try to remove and replace the damaged back panel – Ikea actually offers replacement parts, you just need to specify the correct size.
For replacement: Usually, the back panel is either slotted in or nailed. Nail remnants can be carefully pulled out, then the new panel inserted.
To prevent further moisture damage, you can treat the surface with a clear furniture varnish. This helps repel water. It’s important to act quickly, just like you are doing now.
V
vinli
16 Oct 2021 13:58
The back panel of the Kallax shelf is usually made of thin chipboard with a melamine coating. If liquids penetrate to the core, the chipboard swells due to moisture absorption and loses its load-bearing capacity.
Repairing swollen areas is not effective in the long term because the material structure is damaged. Replacing the back panel restores stability.
Kallax replacement parts can be obtained through Ikea customer service, or alternatively, you can have a chipboard panel of similar thickness cut to size at a hardware store.
Before installation, it is recommended to prime or seal both sides to prevent future water damage.
One more tip: The back panel provides the main lateral stability; if it is damaged, it is best to temporarily secure the shelf until the replacement is done.
PECLARISSA
16 Oct 2021 14:05
Kinbu schrieb:
For replacement: Usually, the back panel is simply held in place by friction or nailed.
Oh, that explains it! I had the same issue with my Kallax once—I ended up searching everywhere for how to get that thing off. But a nail puller or small pliers really do the trick.
By the way, when you put everything back together, just add a bit of confidence now and then, and it will work out! And hey, a little prevention helps too. Furniture finish, as mentioned, protects against the next drink spills ;-)
Good luck and don’t get upset—these kinds of mishaps happen to all of us! 🙂
nonfalk50
16 Oct 2021 17:22
Thanks for the answers so far – they’ve been really helpful.
I have a follow-up question: Is it possible to make a back panel yourself if you can’t get a matching replacement from Ikea? For example, using a thin particleboard from a hardware store and cutting it as close to the original as possible? And how exactly should it be fixed to ensure stability and structural support?
I’m also open to advice on the right thickness for the material to avoid overloading or destabilizing the shelving unit.
How do you usually handle this? Thanks!
