ᐅ KALLAX Cabinet Became Brittle Due to Moisture Exposure – Should I Replace or Repair It?
Created on: 24 Feb 2024 14:37
Magemau
I recently had a KALLAX shelving unit from IKEA that I originally used in the living room, but there was some moisture contact on one of the lower shelves due to a minor water damage. Now the shelving material at exactly that spot has become quite brittle, it’s splintering and feels very dry.
My question to the community is: Is it worth repairing the shelf, or is it more reasonable to replace the entire affected part or even the whole unit because of the moisture damage?
I’d like to estimate whether wood glue or a special material repair product would be sufficient, or if repairing would only be a temporary solution and I should just buy a new shelving unit.
The damage mainly affects the back and bottom of one of the middle compartments.
Looking forward to your experiences and advice!
Magemau
25 Feb 2024 13:52
Josefane schrieb:
Are there any specific requirements for the shelf (e.g., load-bearing capacity, visual quality)?
Thanks for the hint! The shelf is located in the living room and should still look reasonably good there, but it will only be subjected to light to moderate loads, mainly decoration and books (so not too heavy). The damage is limited to the back panel and one shelf board in the middle compartment.
The cause was an accident involving a damp vase, so it was a single exposure to moisture. There is no ongoing moisture penetration, so I hope that no further warping will occur.
In such a case, would it be more advisable to only replace the back panel and repair the shelf board, or to replace both completely?
nonpra
25 Feb 2024 15:47
Replacing only the back panel is usually simple and cost-effective, as most KALLAX models have basic back panels that are also available separately.
I would recommend replacing the bottom panel if it is broken or delaminating, especially if you want the shelf to last a long time. Repairing it only postpones the issue.
SUBEN60
26 Feb 2024 11:22
Magemau schrieb:
The shelf is in the living room and should still look reasonably good there, but it will only be subject to light to moderate use
Based on the detailed description, I recommend the following approach:
1. Replace the back panel with a new original IKEA part if available, as back panels are usually made of thinner fiberboard that is inexpensive to replace and easy to restore visually.
2. Check the bottom panel for warping: Is it bent or just superficially cracked? Replace it if warped; otherwise, repair it with wood filler and ensure sufficient surface sealing.
3. Finally, the surface should be treated with a well-adhering protective varnish to prevent future moisture damage.
This will make the shelf sturdy and visually acceptable again.
Jukin
26 Feb 2024 15:08
SUBEN60 schrieb:
Finally, the surface should be treated with a well-adhering protective coating to prevent future moisture damage.
I can only confirm this. Applying a sealant such as parquet varnish or furniture oil prophylactically does no harm, especially on the cut edges of chipboard, which can absorb a lot of moisture.
If anyone feels like replacing the parts: spare parts for KALLAX are often available at IKEA, so it’s worth inquiring directly there.
