ᐅ My Kallax became unstable after being stored on the balcony – is restoration possible?
Created on: 26 Dec 2023 18:23
BauPeterHello everyone,
A few months ago, I bought an IKEA Kallax shelving unit and stored it on my balcony during the warmer months. Now that the weather has become cooler and more humid outside, I’ve noticed that the unit has become noticeably more wobbly – its stability has decreased, even though I reassembled it indoors. My question: Are there ways to restore the stability of a Kallax shelving unit after extended outdoor storage? Is it possible to tighten screws, treat the wooden parts, or take other measures to regain the original strength? I would appreciate any expert advice and tips on how to make the shelf stable again without having to replace it entirely.
Basically, moisture can cause expansion and related deformation in engineered wood products like Kallax shelves. This affects the stability of the joints. Retightening screws is a sensible first step because swelling often loosens the connections. If the panels have become wavy, you can try to reduce moisture by carefully drying them at room temperature. Alternatively, treating the surfaces with wood preservatives or sealants is also an option. However, avoid forceful splitting stresses, as the material has already been weakened by moisture.
In addition to readjusting the screws, I recommend systematically checking all connection points. Kallax modules are made of chipboard with a melamine coating, which does not handle moisture damage well. Therefore, drying from the inside is particularly important. It might be possible to stiffen the overall structure by tightening the bottom supports and stabilizing back panels. Replacing panels is more labor-intensive, especially due to the specific sizing. A slight shrinkage process is not uncommon, which can cause gaps that weaken stability.
RENMA schrieb:
Kallax units are made of particleboard with a melamine coating, which does not tolerate moisture damage well.This raises the question for me: How resistant are melamine coatings to fluctuating humidity levels? And to what extent can we expect the dimensions of the wood-based material to "normalize" again after drying? I am concerned that if the shelf has been stored outdoors, the internal structure could be irreversibly compromised. The question is whether tightening the screws afterward is only a temporary fix.
Hello BauPeter,
I can completely understand how frustrating this situation is. Generally, the best approach is to allow the piece of furniture to dry slowly and evenly to relieve any tension. This means not placing the shelf directly next to a heater or in direct sunlight, but rather keeping it at room temperature. If the fasteners become loose, carefully check the screws or dowels and replace them if necessary. I also recommend leveling the shelf with a spirit level, as small unevenness in the floor can increase wobbliness. If there are any back panels installed, make sure they are securely attached, as they are important stabilizers.
I will go into a bit more detail:
The construction of the IKEA Kallax is based on melamine-coated chipboard panels, which are resistant to scratches and surface moisture but tend to swell and shrink when exposed to prolonged moisture at the material level. If the shelf is left on a balcony for some time, it is subjected to significant climatic stress (temperature and humidity fluctuations).
Loss of stability usually occurs at the connection points, where dowels and screws loosen from the glued wood-based panels or the wood has swelled internally. A systematic setup with multiple fixed points (e.g., additional brackets or metal angles) can help here. It is essential to retighten the screws. At the same time, fine sandpaper can be used to smooth swollen edges, allowing for a more precise reassembly.
Regarding treatment options: Applying a wood protective varnish once or twice is helpful for sealing the surface, but it does not restore material stability. The best recovery process consists of:
1. thorough and gentle drying
2. practical retightening of all fasteners
3. if necessary, reinserting dowels and screws
4. if necessary, adding stabilization elements such as angle brackets.
The substrate and installation location also play a significant role, as the Kallax can stand somewhat unevenly due to its leveling feet. Replacing rounded feet with small felt pads and checking with a spirit level stabilizes the unit.
