ᐅ KALLAX Back Panel Coming Loose After Several Months – How to Reattach?
Created on: 25 Jun 2016 14:07
Jujadan
Jujadan
25 Jun 2016 14:07
About six months ago, I bought an IKEA KALLAX shelf and only recently noticed that the back panel is starting to come loose in several places. The back panel is made of a thin particleboard, which originally seemed to be properly attached. Now it can be easily lifted and feels generally unstable.
My question is: Has anyone experienced the back panel of the KALLAX shelf coming loose after a few months? What is the best way to fix it without damaging the shelf’s structure or leaving unsightly holes? Are there recommended methods or tools that can help with reattaching it?
I would appreciate any practical tips or personal experiences!
Tarmau
25 Jun 2016 14:43
Jujadan schrieb:
The back panel is made of a thin particleboard, which originally seemed to be properly fixed.
This problem is well known. Back panels are often only attached with small nails or staples that come loose over time.
I recommend securing the back panel with screws, ideally small wood screws with a countersunk head. These create minimal stress and hold the panel effectively. It is important to pre-drill before screwing to avoid splitting the material. Alternatively, mounting brackets or angle irons can be used if the back panel requires a stronger connection to the frame.
KauNicklas
25 Jun 2016 15:05
A small tip: Felt pads or sealing tape placed between the back panel and the frame can help reduce vibrations. Then simply secure them with small screws or furniture nails.
leteo
25 Jun 2016 15:21
I also had similar issues with my KALLAX. I fixed the back panel by nailing it in place with small nails and additionally screwed in small battens on the backside to hold the panel firmly. Since then, nothing wobbles, and it still looks neat. It’s a bit of a DIY fix but works perfectly. 🙂
matthewon
25 Jun 2016 16:02
Jujadan schrieb:
Are there recommended methods or tools that can help with reattaching?
One might question why IKEA doesn’t use a sturdier back panel from the start. But practically speaking, you might want to consider using the KALLAX simply as an open shelving unit. Back panels are often overrated and mostly serve as a visual support.
However, if stability is your priority, adding an MDF board as reinforcement could be an option, attaching it to the frame with screws. Just be aware that this will significantly increase the weight and material thickness.
JEREMIAH38
25 Jun 2016 16:30
I’m familiar with the issue of the back panel; I had the same problem. What helped me was tapping the back panel into place at specific points with small nails and also using wood glue-based construction adhesive. This way, it holds better and is barely visible.
I just wanted to say: don’t get discouraged, you can manage this well. And if you have any questions, feel free to reach out!
