I am currently looking into whether an IKEA Kallax shelf is suitable as a hi-fi rack, especially regarding the effects of vibrations. My main question is: How significantly do vibrations caused by bass and speaker operation within the shelf affect the stability and long-term durability of the Kallax?
I imagine that strong bass from subwoofers or floor-standing speakers may transmit vibrations that could impact the joints and material. Are there any insights or experiences on how resistant the Kallax construction (material, connectors, back panel) is to such vibrations? And whether there are ways to improve stability or reduce vibrations?
I am particularly interested in whether vibration loads decrease stability, loosen connections, or eventually cause material fatigue. I would appreciate concrete information and tips on vibration damping or isolation. Thank you!
Hello zihan,
Your topic is indeed very interesting and often underestimated. Vibrations can cause issues in hi-fi setups—not only by degrading sound quality but also by applying mechanical stress to the furniture.
The Kallax shelving unit is primarily designed for light to medium loads. Its panels are made of medium-density fiberboard (MDF) with a melamine finish. The back panel is relatively thin, often just a thin hardboard sheet, mainly providing stability by preventing twisting but not optimized for bearing loads.
Strong bass waves can exert forces that particularly stress the unit’s joints. Specifically, the stability of the connections between the horizontal and vertical panels is important here; these are usually made with dowels and composite wood panels. These joints could theoretically loosen over time due to constant vibrations. Material fatigue may also occur along the edges used.
In your case, I recommend considering the following:
1. Place the shelving unit on a level and vibration-damping surface—rather than directly on the floor, use rubber mats, for example.
2. Reinforce the compartments with additional fasteners, such as extra screws or internal angle brackets, to secure the joints.
3. Reduce vibrations by decoupling the speakers and subwoofer from the shelving unit. This means avoiding placing them directly on the shelves; instead, use specialized absorbers or rubber pads.
4. Optionally, reinforce the back panel with thicker or sound-absorbing materials to improve vibration damping.
I’m curious: How are your speakers positioned on the Kallax? Are they actually placed directly on the shelves or next to them? Are you willing to make some DIY modifications?
Best regards!
Best regards!
Domau0 schrieb:
Vibrations can indeed cause problems with HiFi setupsExactly! The Kallax is actually a pretty cool base, but vibrations are like little troublemakers that sneak in unnoticed. 😜 Imagine every bass kick as a mini earthquake alarm for the shelf – over time, no wooden panel enjoys that.
My recommendation would be to place the speakers beside it or use rubber feet under them. And of course, nobody wants a crooked HiFi shelf that wobbles while listening, right? ;-)
Give the shelf some space to breathe, make it cozy, and your sound will thank you! 🙂
RABLA schrieb:
Vibrations can loosen connections over time.I would add that the Kallax was never designed for high-end HiFi. The shelf is a piece of furniture intended for light loads and mass, not for dynamic stress.
We’re not just talking about vibration damping here, but the fundamental unsuitability of the material and construction. Anyone serious about HiFi needs a stable, screwed-together, and ideally damped rack—not some kind of beverage crate unit in the living room.
So: The question is certainly valid, but my answer is clear—Kallax is not a solution for sustainable HiFi setups. It’s not just a little shaky; it’s a compromise with limitations.
Hey Zihan and everyone else!
I really appreciate that someone is looking into the stability of Kallax in the HiFi context – this is definitely a popular question! The shelf is very practical, super flexible, and that’s why many people use it.
But I have the exact same concern about vibrations. I once placed rubber mats under my speakers, and since then the shelf feels noticeably steadier and more stable. Another tip: line the shelves where you put subwoofers with foam or damping material.
What I want to say is: there are plenty of things you can do, so don’t write it off right away! With a few small tricks, it works out. I’m definitely very happy with the solution I have! 🙂
