ᐅ Is there a way to secure Ikea Besta doors with magnetic catches?
Created on: 18 Mar 2021 09:13
Rilo45Is there a way to make Ikea Besta doors close magnetically? I have a Besta unit with doors that do not come with magnetic catches by default, and I am looking for a practical solution to ensure the doors stay closed on their own and securely, without modifying the furniture or using complicated constructions. I am especially interested in recommended magnetic catch solutions that are easy to install, visually unobtrusive, and reliable. Additionally, I would like to know what to consider during installation, particularly regarding the strength of the magnets, whether to attach them on the surface or recessed into the door, and their durability. Experiences and tips on suitable types of magnets and their mounting are also very welcome.
Basically, it is possible to close Ikea Besta doors magnetically by using so-called furniture magnets or visible magnets. These magnets are available as neodymium or ferrite magnets, with neodymium magnets often preferred due to their stronger holding power.
For installation, it is recommended to attach one magnet to the inside of the door and a corresponding metal plate or counterpart to the cabinet frame. This can be glued directly, screwed on, or recessed. It is important that the positioning is precisely aligned so the door closes securely and flush.
When choosing the magnets, make sure the holding force is sufficient—around 1 to 2 kg (2.2 to 4.4 lbs) of pull force. Higher forces may hold the door well but could also cause injuries to children if the door closes unintentionally.
In summary:
- Prefer neodymium magnets
- Align positioning exactly
- Mount using screws or strong two-component (2K) adhesive
- Holding force of about 1–2 kg (2.2–4.4 lbs) recommended
A visually discreet option is to use flat recessed magnets, which can be set into the door and cabinet frame with a router.
In summary:
In addition to draleo: IKEA does not use magnetic catches as standard for the Besta system, which suggests that the wood or composite material of the doors can be quite thin. For this reason, I recommend strong neodymium cup magnets, which are relatively flat in design and offer very high holding force.
These magnets can be easily attached with appropriate screws, so the load does not rely solely on adhesive. Alternatively, there are flat adhesive pads, but the glue often is not suitable for long-term stress.
Based on experience, it is important to check before installation whether the magnetic attraction is not too strong—especially with small doors, this can cause problems when opening. The alignment of the door must also be precise to ensure optimal contact.
In short:
- Cup magnet with screw mounting
- Test holding force beforehand
- Ensure exact alignment
- Adhesive strips as an alternative, though less recommended
In short:
usbla schrieb:
IKEA does not typically use magnetic catches for the Besta system, which suggests that the wood or composite material of the doors may be quite thin.This is an important point. Besta doors usually consist of a thin core layer with an edge banding that must be handled very carefully during any modification to avoid damage.
The following challenges arise when installing magnets:
- Routing the magnets should be done so as not to weaken the door.
- Screws should not be placed into the outer decorative layers or the edges.
- Alternatively, bonding with a high-quality specialized adhesive can be considered.
I recommend the following steps before installing magnets:
1. Check the door material (thickness, construction)
2. Choose the appropriate magnet type (flat, cup, disc magnet)
3. Precisely determine positions (using calipers and marking tools)
4. Carry out proper installation (possibly using a routing template)
Planning the holding force is also important. For small doors, magnets with about 0.5 to 1 kg (1 to 2 lbs) pull force are sufficient. Magnets that are too strong can cause strain when opening or even damage the doors.
Question for Rilo45: What are the door dimensions and material of your Besta doors? This significantly affects the choice of magnets and installation methods.
Domau0 schrieb:
Question for Rilo45: What are the door dimensions and material of your Besta?Thanks, that’s a good starting point. My Besta doors are about 38 cm (15 inches) wide and 64 cm (25 inches) high, made from a 16 mm (5/8 inch) thick particleboard core with a melamine coating. The surface is smooth and white. The doors aren’t particularly heavy, I estimate around 2.5 to 3 kg (5.5 to 6.5 lbs).
I’d prefer to avoid holes or recesses, so a solution that can be installed with minimal visible damage would be ideal. Adhesive magnets are interesting if they hold up long-term.
Does anyone have experience with how long such adhesive solutions last on furniture like Besta, especially with the stress of opening and closing multiple times a day? Or are screws safer despite the aesthetic drawbacks? Thanks for any input.
Regarding the durability and installation of adhesive magnets on Besta doors, I can share the following insights based on experience and practical knowledge:
Introduction:
Adhesive magnets offer a quick and visually discreet solution, especially suitable for smooth surfaces typical of melamine coatings.
Steps:
- Before installation, thoroughly clean the contact surfaces with alcohol to remove grease, dust, and residues. This significantly improves adhesion.
- Use strong two-component epoxy adhesives or industrial-strength adhesives specifically designed for magnetic attachments.
- Apply the adhesive sparingly but evenly to ensure a long-lasting bond.
- Position the magnets preferably on internal areas or edges to minimize their visual impact.
Common mistakes:
- Poor surface preparation (dust, fingerprints)
- Using low-quality adhesive
- Mounting without applying sufficient pressure during curing
Summary:
- Adhesive mounting works well when the surface is clean and smooth
- Using high-quality adhesives and thorough preparation is essential
- Long-term durability can last several years when the installation is done properly
Therefore, a well-executed adhesive installation on Besta doors is a practical solution. For higher loads (e.g., larger doors or frequent use), mechanical fastening with screws is preferable.
Introduction:
Steps:
Common mistakes:
Summary:
