ᐅ Is there a guide on how to make Ikea Besta doors close more quietly?
Created on: 27 May 2023 08:32
Lege6Hello everyone, I have assembled an Ikea Besta shelving unit a few weeks ago and am generally happy with it, but there is one thing that bothers me: the doors close quite loudly and with a bang, which is especially unpleasant at night. I’m wondering if there are any instructions or specific tips on how to make the Ikea Besta doors close more quietly? I’m not only looking for ways to dampen the noise but also whether it’s possible to adjust or optimize the closing mechanism to make it softer without having to upgrade to expensive dampers. Does anyone have experience with simple solutions, official Ikea guidelines, or proven hacks to reduce the noise when closing the doors?
Your question is completely valid, and I have had similar experiences. There are generally several ways to make doors quieter – however, one should not expect to make the doors completely silent without appropriate dampers. Ikea does provide instructions for many of their furniture pieces, but to my knowledge, there is no specific guide or adjustment for quieter doors on the Besta system.
I would have found it more reasonable if Ikea offered factory-fitted hinges with mechanical adjustment and damping. How much noise is tolerable is certainly a matter of personal opinion, but simple adjustments are not always enough.
Does anyone have concrete evidence that a “soft” setting on Besta hinges is available as standard? That would be crucial for the original poster here.
In short: If your Besta doors close loudly, first try adjusting the hinges. Ikea hinges usually have screws that allow you to fine-tune the closing.
If that’s not enough, I recommend attaching silicone buffers or self-adhesive dampers inside the installation area. They are cost-effective and efficient.
Hello Lege6, I completely understand your issue. Doors that slam loudly are not only annoying but can also cause long-term damage to the hinges or the furniture.
I couldn’t find any specific guide from Ikea for quieter Besta doors, but I recommend the following approach:
- First, check the hinges to see if they are properly installed and adjusted; often, a slight readjustment can help the door close more gently.
- If your Besta hinges don’t have built-in soft-close mechanisms, you can retrofit so-called soft-close hinges. Be sure the dimensions and drilling distance match to avoid compatibility issues.
- As an inexpensive alternative, small self-adhesive silicone door buffers can be attached to the inner edge of the doors or the carcass. These significantly reduce the impact noise.
If your doors are still relatively new, a readjustment is definitely worthwhile. The older the furniture, the more likely wear and warping will be a problem.
Hey, Besta doors and those "slamming sounds" are something I know all too well! 😅 From my experience, soft sealing strips or small rubber buffers work best—they absorb the energy from the door closing quite effectively.
What I find especially cool is that you can customize the damping solutions to fit the atmosphere of your living room. Just experiment with different types of buffers, so your home won’t end up feeling like a silent museum but still nicely soundproofed.
And yep, often simply readjusting the screws helps; that’s practically part of the Ikea flat-pack experience 😉
Regarding the question of whether there is an official guide from Ikea on how to achieve quieter closing of Besta doors, I have not come across any such document. The hinges used by Ikea for Besta are mostly standard hinges without integrated soft-close mechanisms.
However, it is possible to replace them with soft-close hinges if the screw holes are compatible – these mechanically slow down the closing process.
Alternatively, the following practical measures can be considered:
- Adjusting the hinges to optimize the closing pressure
- Attaching self-adhesive silicone bumpers to the door frame
- Installing externally mounted hinge dampers
The best solution depends on individual user behavior and the specific characteristics of the door.
