ᐅ Is there a correct order for assembling the Ikea Brimnes wardrobe?
Created on: 24 Aug 2023 09:23
liang
liang
24 Aug 2023 09:23
Hello everyone, I am currently facing the challenge of assembling our new Ikea Brimnes wardrobe. I noticed that the assembly instructions are quite detailed but don’t clearly state whether there is a strictly required order to follow during assembly to avoid problems later on. I’m interested to know if anyone here has experience with the Brimnes wardrobe and can confirm whether there is an optimal or even necessary order for assembly. For example, is it important to assemble the side panels first before attaching the back panel, or can it be done in a different sequence? Also, are there typical mistakes to watch out for when putting the different parts together? I want to make sure everything is stable and the assembly goes as smoothly as possible. Thanks in advance for your tips and advice!
Cecilera66
24 Aug 2023 11:07
For the Brimnes wardrobe, I recommend always assembling the main structure first, meaning the side panels and shelves. The back panel is usually installed last since it increases stability. Without the side panels, it is difficult to align the back panel correctly. This also helps prevent assembly errors and ensures a stable fit.
Laukau5
25 Aug 2023 07:41
Your question about the correct order for assembling the Ikea Brimnes wardrobe is very valid, as the instructions sometimes allow for different approaches. Based on my experience and technical details, I would recommend the following assembly process:
- First, connect the side panels with the bottom and top shelves. These form the base and provide initial structural stability.
- Next, insert the shelves and additional panels so that the structure is secured with dowel joints. This is important to prevent shifting later on.
- Then, attach the back panel—make sure it is positioned correctly and that all screws are tightened evenly to avoid warping.
- Only in the final step should you install the doors or drawers, as fitting these components earlier can interfere with the assembly process.
A common pitfall is attaching the back panel too early, which can make inserting the shelves more difficult or cause misalignment. My question to you: Have you unpacked and checked all the parts? Missing or damaged wooden elements can disrupt the entire sequence.
sinhau
25 Aug 2023 19:54
Laukau5 schrieb:
My question to you: Have you unpacked and checked all the parts yet?
This is a very important step that I want to emphasize. Sometimes the assembly sequence in the instructions is correct, but damaged or missing parts can lead to problems during the build.
After careful preparation, I recommend a structured approach to assembling the Ikea Brimnes wardrobe in three phases:
- Phase 1: Assemble the frame structure of the side panels and shelves for connections. This forms the basic framework.
- Phase 2: Install the fixed shelves and center partitions, and secure most of the connecting elements. At this point, everything fits together, but the wardrobe is still flexible.
- Phase 3: Install the back panel and doors to finalize the assembly, which gives the wardrobe its stability. Always secure the back panel with multiple screws and make sure it lies flat.
Typical mistakes include attaching the back panel too early or incorrectly fitting the connecting clips. I also recommend loosely fitting all components together before fully tightening the screws to check alignment.
If you like, I can also prepare a short checklist to make the assembly process clearer.
