ᐅ Is the Ikea Metod hanging rail also compatible with Faktum wall cabinets?
Created on: 18 Sep 2014 21:56
stephonikeaS
stephonikea18 Sep 2014 21:56Hello,
has anyone here had experience with the new Metod hanging rail for kitchen cabinets? I have a Faktum kitchen and will be moving soon. I would like to take it with me and am wondering if this could make things easier. Specifically, if I could mount my Faktum wall cabinets on the Metod hanging rail...
Does anyone know and can provide an answer?
Thank you in advance
stephonikea
stephonikea
IKEA-Experte19 Sep 2014 10:35Hello,
in the end, installing the brackets on the carcass would be more time-consuming than hanging the cabinets individually as before, assuming Ikea would provide them in the required quantity.
Eumeltier22 Sep 2014 12:15Hello,
Here is what I did:
Since the cabinets sit flush against the tile backsplash at the bottom anyway, I needed some space at the top. I also have difficult walls (internal insulation), so I needed long screws to ensure everything holds securely. Additionally, in some spots where I would have needed to drill, there were utility lines running...
I bought standard mounting rails from the hardware store. I placed the upper cabinets on the floor and drilled holes in the rails at the correct points. Then, I put hex bolts in from the back and tightened nuts on the front.
I anchored the rails to the wall using wall plugs, then hung the upper cabinets on the protruding threaded bolts. I aligned them with washers as usual – perfect.
Regards,
Martin
Here is what I did:
Regards,
Martin
stephonikea23 Sep 2014 09:30Thank you for your replies.
Am I correct in understanding that the hanging rails are not sold individually?
The solution with the rail (Martin) sounds good.
Have a nice day and best regards,
Steph
Steph
IKEA-Experte26 Sep 2014 23:38Only the appropriate mounting brackets that are installed inside the cabinets are not available for purchase.
