ᐅ Is it possible to equip Ikea Besta units with casters to make the furniture more flexible?
Created on: 18 Mar 2020 19:23
Ixgo55Hello everyone, I’m planning to make my Ikea Besta shelving unit more flexible by adding casters. I’m particularly interested in whether it is mechanically possible and stable enough to securely mount the usually quite heavy components on wheels. It would also be useful to know which types of casters are best suited, whether special mounting points need to be used, and if this modification significantly improves everyday usability, for example to make vacuuming or rearranging easier. Does anyone have experience or specific tips on how to fit casters to Ikea Besta furniture without compromising stability? I’m looking for both technical advice and recommendations on suitable casters or mounting options.
chenValeri18 Mar 2020 20:05Yes, you can equip Besta shelves with casters. It is important to use sturdy casters with a locking brake. Casters that can be screwed to the underside of the shelf panel are best. Make sure the casters are rated for the weight of the shelf; otherwise, it may become unstable or difficult to move.
Hello! Your question is actually very well thought out, as the Besta system is not originally designed for casters, but it can certainly be modified for that purpose. It’s important to realistically assess the load on the casters and choose high-quality materials that also have a locking brake to prevent unwanted movement.
The most stable option is usually to attach the casters to a wooden base plate that you screw onto the bottom of the cabinet. This helps distribute the load more evenly and protects the furniture. Some people use thicker plywood or OSB boards as an intermediate layer to mount the casters on and then fix this plate to the cabinet. This way, you prevent damage to the narrow side panels caused by point loads.
Additionally, adding an extra support in the middle is helpful. Depending on the height of your Besta unit, it could otherwise tip over or twist when moved. It’s also advisable to choose casters with rubber tires so the furniture will roll more smoothly over different types of flooring.
If you want to try different configurations later, you can also choose casters with locks that can be permanently engaged to keep the furniture firmly in place when you don’t want to move it.
If you like, I can provide more details about mounting on the side panels or share tips on how to best distribute the load.
Ethan schrieb:
It is important to realistically assess the load on the casters and choose high-quality materials that also have a locking brake to prevent unwanted rolling. Thanks, that sounds reasonable. What maximum load capacity would you recommend for a single pair of casters if the Besta is meant to carry about 80 kg (176 lbs) plus contents like books? Ethan schrieb:
The most stable solution is usually to attach the casters to a wooden board, which you then screw to the bottom of the shelving unit. That makes sense to distribute the point load. Would a plywood board 18 mm (0.7 inches) thick be sufficient, or should you go thicker? Another point is modifying the feet of the Besta – if they are replaced by casters, you have to at least partially remove or compensate for the original feet. Does anyone have experience with the best way to handle this?
Thanks in advance for the helpful information!
Great question – I equipped my Besta with casters myself and can say: it’s definitely worth it!
I chose casters with a load capacity of 50 kg (110 lbs) each, so with 4 casters, the shelf can easily support 200 kg (440 lbs), which adds stability. A locking brake is essential; otherwise, the furniture will roll away while vacuuming 😉
I used 18 mm (0.7 inch) plywood, which held up perfectly, and the casters were mounted securely. The shelf won’t become unstable if you position the board flush and fasten it well.
I unscrewed the original feet and then adjusted the plywood board accordingly – it’s important that everything stands flat and level; otherwise, the furniture will wobble. A good cordless drill helps a lot here.
Good luck! You’ll enjoy the flexibility of being able to rearrange your furniture easily later on.
Ixgo55 schrieb:
Would an 18 mm (0.7 inch) plywood board be sufficient, or should it be thicker?
Ixgo55 schrieb:
Another point is modifying the feet of the Besta – if you replace them with casters, you have to at least partially remove or compensate for the original feet. Has anyone got experience on the best way to handle this?
For clarification: Those looking for a durable and secure solution should ensure to
- use casters with a minimum load capacity of 50 kg (110 lbs) each,
- securely mount them on a multiplex board at least 18 mm (0.7 inches) thick,
- fasten the board firmly and squarely to the shelf bottom with appropriate screws,
- add additional cross braces for stabilization if necessary,
- and always use lockable casters to prevent the furniture from moving during use.
Removing the original Besta feet is necessary to lay the multiplex board flat; otherwise, uneven height or instability may occur. If the furniture weight including contents is about 80 kg (176 lbs), the above load capacity specifications are sufficient.
Additionally, remember that casters with rubber tires not only improve mobility but also protect the floor, especially on parquet or laminate flooring.
Overall, the modified version is a practical and proven solution to significantly increase the flexibility of the Besta furniture without compromising stability.
