ᐅ Which screwdriver sets are particularly recommended for repairs on Ikea Besta units?
Created on: 11 Nov 2024 08:12
Kau31Hello everyone, I am currently repairing an IKEA Besta shelving unit and am looking for a screw set that is particularly suitable for typical repairs on this piece of furniture. I am mainly interested in a durable selection of screws and possibly bits that are highly recommended for connecting the different components. It would be great if the screws offer corrosion protection and include the right sizes for the most common parts (e.g., carcass, back panel, doors). Which sets or individual items have you used that provide good results when repairing IKEA Besta furniture? Thanks for any helpful recommendations and tips!
Hello Kau31, your request is very precise, which I appreciate. For repairs on IKEA Besta furniture, I recommend the following approach:
- First, look for a screw set with various lengths in M4 size, as these are most commonly used for Besta.
- Make sure the set includes both pan head screws and flat head screws, as the Besta system uses both for different components.
- Zinc-plated screws are ideal for rust protection if your furniture is placed in a slightly humid area.
- For bits, I suggest Torx 20 and Phillips PH2, since Besta often uses these head types.
A common mistake is applying too much torque to one screw type. This can damage the furniture, so it’s better to screw carefully and with a gentle touch.
In summary: A versatile set with M4 screws, zinc plating, pan head and flat head screws, as well as Torx 20 and PH2 bits covers most repairs. Hope this helps you!
Jensson hits the mark, especially the mention of the appropriate head types and the use of suitable bits is important. Additionally, I would recommend paying attention to screws with thread designs specifically made for wood or chipboard when purchasing. Since Besta is mostly made from furniture panels, these provide better grip and reduce material damage when re-inserting.
Jensson schrieb:
A common mistake is applying too much torque to a screw type. This can damage the furniture, so it’s better to screw in carefully. This is an important tip, and I would like to add that a torque wrench can be quite useful when repairing furniture like Besta, especially when replacing original screws to avoid overstressing the material.
I also recommend using sets that include electro-galvanized screws to prevent corrosion in the long term, particularly if Besta is placed in kitchen or living areas with slightly increased humidity.
