ᐅ IKEA Metod: How can I clean glass cabinet doors without leaving streaks?
Created on: 27 Aug 2023 14:23
folo66Hello everyone, I have a question about cleaning glass fronts on IKEA Metod kitchens, specifically how to get them spotless and streak-free. Since Metod cabinet doors often feature glass panels or inserts, I want to clean the surfaces without leaving streaks or residue. So far, I have been using just water and a microfiber cloth, but the results are rarely completely streak-free. Sometimes I use glass cleaner, but then the surface seems to look a bit dull and becomes unattractive again after a short time.
Has anyone had experience with a specific cleaning method or product to get the glass fronts truly clean and streak-free? Are there any tips to better remove grease or dust residue? How should I proceed to avoid damaging the glass edges or door frames?
I’m looking forward to helpful tips and suggestions on how you handle this!
Hello folo66, I completely understand your concern. Glass facades can indeed be tricky, especially since they tend to show streaks quickly. My recommendation is based on years of experience:
- First, I suggest wiping off any coarse dust or particles with a dry, soft microfiber cloth. This helps prevent dirt particles from scratching the surface.
- Next, I use a mild glass cleaner, applied to the cloth rather than sprayed directly onto the glass. This prevents liquid from seeping into the frames.
- For a streak-free finish, make sure the cloth is clean and use a second dry microfiber cloth for polishing.
- The room temperature is important: in direct sunlight, the cleaner dries quickly and is more likely to leave streaks.
Regarding grease: a small drop of dish soap in water really helps—I assure you it removes grease thoroughly without damaging the glass edges.
I hope this helps!
I hope this helps!
Hey folo66, I totally understand your search for the perfect cleaning method! 🎯 Glass surfaces really look great but can be tricky to clean 😅
Here’s a little magic formula from me:
- Mix white vinegar with water at a ratio of 1:3 and put it in a spray bottle.
- Spray the mixture onto a microfiber cloth, not directly onto the glass.
- Wipe gently and then polish with a clean, dry cloth.
This removes grease without being harsh. And those streaks? Almost like magic. Don’t worry: glass edges are sturdy – vinegar won’t damage them unless you happen to live in an aquarium 😉
Good luck, and let me know if it shines!
uslis47 schrieb:
Regarding grease: A small drop of dish soap in the water really helps – I promise it removes grease thoroughly without damaging the glass edges.Thanks for the tip! Honestly, I rarely used dish soap with glass panels because I was afraid the residue might leave dull spots. Have you never had that problem?
dijan schrieb:
Simply mix white vinegar with water in a 1:3 ratioI haven't dared to use vinegar so far, mainly because of the smell and my concern that the coated frames might get damaged. Are there any experiences on how long glass panels can be treated with vinegar without causing harm?
I’m also considering whether microfiber cloths with different textures (one softer, one a bit rougher) are useful depending on the level of dirt – does anyone have recommendations?
Looking forward to your opinions!
folo66 schrieb:
Honestly, I rarely used dish soap on glass fronts because I was worried that residues could leave dull spots. Have you ever had that problem?Hello folo66, I like to use dish soap, but very sparingly and always diluted with water. It’s important to wipe thoroughly with clean water afterward to avoid any residue. This way, the glass stays clean and clear.
folo66 schrieb:
I also haven’t dared to use vinegar so far, mainly because of the smell and my concern that the frames (usually coated) might be damaged.The vinegar smell fades quickly. I agree, you shouldn’t let the liquid sit on the surfaces when cleaning. Wiping it off immediately also protects the frames and seals.
Regarding microfiber cloths: I have two types – one with a soft side for polishing and one with a slightly coarser texture for initial cleaning. This method works very well for me.
