ᐅ IKEA Metod Assembly Errors: What Tips Can You Share?
Created on: 30 Dec 2015 09:17
U
Ususfi
U
Ususfi
30 Dec 2015 09:17
Hello everyone, I am currently in the process of installing my IKEA Metod kitchen and have noticed some issues that I am certain are due to installation errors. For example, some drawers are misaligned, and the working height doesn’t quite match up. I’m wondering if you have encountered similar challenges and what specific tips you can offer to avoid or fix common installation mistakes with the IKEA Metod kitchen? I am especially interested in advice on correcting misalignments, the proper way to attach the brackets, and ensuring the cabinets are aligned evenly with each other. Looking forward to your experiences and practical recommendations!
memiriam
30 Dec 2015 11:04
Ensure the base surface is perfectly level. Before installation, check each cabinet individually and combined using a spirit level. Fasten the connecting parts loosely at first, align everything, and then tighten securely.
Louie
30 Dec 2015 12:37
Hello, I understand that assembling the Metod system can sometimes be quite tricky. I always recommend carefully reviewing the instructions before you start and avoid fully tightening everything right away. In my experience, it often helps to loosely attach the main structures first and then adjust the drawer fronts step by step. Especially with drawers, it’s important to align each front individually before securing it permanently. It’s also a good idea to use a level repeatedly during assembly, as small deviations can quickly add up. If possible, allow some time for adjustments—this will save you frustration later on.
GLORIA
31 Dec 2015 07:23
As a general recommendation for assembling IKEA Metod, please consider the following points: - Check the floor level using a precisely calibrated spirit level. Unevenness can be compensated with the cabinet leveling feet. - Before fully tightening the screws, all connections should first be loosely fixed to allow optimal adjustment. - Use a second person to check right angles and to assist in holding the units during screwing. - Pay close attention to the correct positioning of the corner brackets on the carcasses, as incorrect placement is often the cause of misaligned fronts. - The fronts, especially on drawers, must be adjusted separately since even small deviations can affect the overall appearance. - Avoid overtightening the screws to prevent deformation. Additionally, I recommend using tools carefully: a cordless drill with torque control helps prevent applying excessive force. This effectively reduces assembly errors.
memiriam
31 Dec 2015 08:45
GLORIA schrieb:
Before final tightening, all connections should first be loosely secured to allow for optimal adjustment.
This is exactly the crucial point that many underestimate. First loosely secure, then align, then tighten.
Louie
2 Jan 2016 15:29
GLORIA schrieb:
Use a second person to check the right angles and to help hold the modules during screwing.
I can only confirm that. Especially when working alone, small misalignments can easily occur. Having a second person to check or hold the components greatly reduces installation errors.
Also, a tip: carefully check the carcasses for minor defects before assembly. Sometimes elements are not cut perfectly or are slightly warped, which can cause issues later. Return or replace such parts if possible.
