ᐅ IKEA Metod Kitchen – 2.8 cm Countertop with Induction Cooktop, Oven, and Drawer
Created on: 27 Oct 2015 17:39
Yuliah
Yuliah
27 Oct 2015 17:39
I’m new here and registered specifically to get some advice regarding our new IKEA kitchen. We’ve already solved the dishwasher issue; we ordered a Siemens with a VarioHinge in XXL, which is supposed to fit.
Now we have a problem with the cooktop. We would like to choose induction (not from IKEA), but we were told that in this case you cannot install a drawer under the oven and have to use two panels instead. Is there any way to avoid this? I mean, is there any induction cooktop that still allows keeping the drawer below despite having a countertop only 2.8 cm (1.1 inches) thick? Is that 1 cm really such a problem since supposedly it would work with 3.8 cm (1.5 inches)?
Maybe someone can help us. We would appreciate it.
Kind regards
Yuliah
IKEA-Experte
27 Oct 2015 21:21
that depends on the drawer height. If the front height of the top drawer is 20 cm (8 inches), installing the cooktop should not present any problems.
Z
zetterberg
28 Oct 2015 07:21
Edit ...
A 20cm (8 inches) drawer front with a low drawer behind it is safe.
Yuliah
28 Oct 2015 07:56
thanks for the help. Do I have to install the drawer necessarily above the oven, or did I understand correctly that I can also install it below the oven if I don’t use a Maximera?
Julia
IKEA-Freund
28 Oct 2015 10:23
I would recommend checking the installation instructions provided by the respective manufacturers. For example, for the Miele KM 6322:
To ensure proper ventilation of the appliance, a minimum clearance is required below the unit in relation to an oven, an intermediate shelf, or a drawer. The minimum distance from the underside of the cooktop to
– the top of the oven must be 15 mm (0.6 inches).
– the top of the intermediate shelf must be 15 mm (0.6 inches).
– the bottom of the drawer must be 75 mm (3 inches).
I would follow these guidelines—if only for warranty and guarantee reasons. Most manufacturers also specify minimum countertop thickness.
IKEA-Freund
IKEA-Experte
28 Oct 2015 13:26
I didn’t even notice the oven mentioned in the title. Do you want to install the oven at the bottom with a drawer above it? That would be very impractical unless you are extremely short. The drawer under the oven is very useful for baking trays and similar items.
