ᐅ IKEA BESTA – Which Tools Are Most Practical for Repair Work?
Created on: 2 Aug 2020 09:37
kenzeki
kenzeki
2 Aug 2020 09:37
I recently assembled some IKEA Besta furniture pieces, and after a while, I’ve encountered minor issues like squeaking hinges, loose connections, and slightly unstable doors. Since I don’t want to replace the furniture but rather repair it, I have the following question: Which tools are the most practical and efficient for repairing and stabilizing IKEA Besta furniture?
I am especially interested in tools you recommend for tightening screws, fixing damage to the hinges, or repairing cam lock fasteners and furniture carcasses.
Do you have experience with specific screwdrivers, cordless drills, special bit sets, or even particular accessories that make the repair easier? Recommendations for high-quality products or especially handy tools are also welcome.
I look forward to your practical tips and experiences!
GAGRAHAM
2 Aug 2020 10:02
Hello kenzeki!
What a great question! I really appreciate when someone wants to repair furniture instead of just throwing it away! 🎉 For IKEA BESTA, I can recommend the following:
- A good cordless drill with adjustable torque is invaluable; it prevents over-tightening screws while still giving you enough power!
- Special bits for Torx screws (usually T20 for IKEA) are a must! They fit perfectly and prevent the screw heads from rounding off.
- A small, high-quality Phillips screwdriver for fine adjustments on hinges.
- A rubber mallet can be helpful when you need gentle levering on cam connectors without damaging the wood.
Very important: high quality! Cheap tools only lead to frustration. With these items, you’ll be well prepared! Just give it a try, and if you have questions, feel free to ask here—we’re happy to help! 😊
Foster63
2 Aug 2020 11:29
Hello kenzeki,
First of all, I think your concern is very reasonable. For repairs on IKEA BESTA furniture, the following tools are especially useful:
- A high-quality, adjustable cordless screwdriver with Torx bits (especially T20) for most screws
- A small, ergonomic Phillips and flathead screwdriver for delicate work on hinges
- A small ratchet with suitable bits for hard-to-reach areas
- A rubber mallet or a small wooden block for gently tapping in dowel connectors
For stability and fine adjustment, I also recommend being careful not to overtighten the screws, as the particleboard material is quite sensitive. For springy or wobbly parts, wood glue can be used as additional support, but it should be applied sparingly.
In summary: good-quality screwdrivers with the right bits, gentle tapping tools, and some finesse are the most helpful aids for repairs on IKEA BESTA furniture.
PRA64
3 Aug 2020 08:44
I would like to provide a structured overview of the tools that are especially useful when repairing IKEA BESTA furniture:
1. Screwdrivers, ideally Phillips PH2 (for hinges) and Torx T20 (for connectors)
2. Cordless drill/driver – it is important to have adjustable torque settings to avoid damaging the material
3. Bit set with various Torx and Phillips bit sizes
4. Rubber mallet for gently tapping in dowels or connectors
5. Small pliers or clamps for holding parts in place
6. Wood glue – use sparingly to reinforce several weak joints
Common mistakes during repairs include over-tightening screws or mixing different fittings that are not designed for BESTA. Therefore, always use the correct tools; IKEA screws usually have T20 Torx heads, which are best handled with matching bits.
Summary: Focus on quality tools to protect the material of the BESTA units as much as possible and ensure long-lasting stability.
lise56
3 Aug 2020 10:17
GAGRAHAM schrieb:
A good cordless screwdriver with adjustable torque is invaluable; it prevents over-tightening screws while still providing enough power!
I would like to point out that although a cordless screwdriver with torque control is useful, it is often used incorrectly. Many users rely on the drill to fully tighten IKEA BESTA screws and overtighten them, which can damage the chipboard core. For precision work, I therefore recommend using manual screwdrivers with good torque feedback.
PRA64 schrieb:
Small pliers or clamps when parts need to be secured
That makes sense, but you should consider the clamping forces in press-fit connections to avoid crushing the surface. When doing repairs, it is especially important to work reliably and durably without causing unnecessary wear to the furniture itself.
Espen
4 Aug 2020 07:32
Torx T20 bits and cordless drill with torque adjustment.
Small Phillips screwdriver for hinges.
Rubber mallet for tapping in the cam connectors.
That's all you need.
