ᐅ Ikea Besta – How Can I Remove Stains from the Surfaces Without Causing Damage?
Created on: 19 Oct 2021 08:37
ken_selami
ken_selami
19 Oct 2021 08:37
I have an Ikea Besta shelving unit with high-gloss surfaces, and unfortunately, some stubborn stains have appeared that cannot be removed by normal wiping. Since I’m worried about damaging the surface with harsh cleaners or too much mechanical force, I’m looking for methods that are as gentle as possible but still effective to remove stains from Besta surfaces without harming the lacquer or material.
Does anyone have experience with removing stains on Ikea Besta surfaces? Which cleaning products or home remedies are suitable, what should be avoided, and what is the best approach to avoid causing damage?
Thanks in advance for any tips!
Leote
19 Oct 2021 09:02
I would start by using warm soapy water and a soft cloth. Avoid abrasive cleaners or scrubbing pads. If that doesn't work, special plastic cleaners are recommended.
Gregory
19 Oct 2021 11:29
In general, you should handle Ikea Besta high-gloss surfaces with care, as they are usually not very scratch-resistant.
Recommendations:
- Use a microfiber cloth, avoid steel wool or abrasive sponges.
- Neutral cleaning agents, such as mild dish soap diluted in water, are safe.
- For stubborn stains, isopropyl alcohol in a low concentration can be helpful, but test it first on an inconspicuous area.
- Avoid acidic cleaners or solvents like acetone completely, as they will damage the surface.
Avoid mechanical stress to prevent scratches.
For grease stains, you can let a drop of dish soap diluted in water sit on the area briefly, then wipe gently.
Seanni
20 Oct 2021 07:13
Hey ken_selami,
I know how annoying those spots on glossy furniture can be! 😤 My advice: try lukewarm water with a few drops of lemon juice; that has worked wonders for me – but please, use only a small amount, otherwise you might end up with dull patches!
Gregory schrieb:
Avoid acidic cleaners or solvents like acetone completely, as they damage the surface.
I totally agree with that! Better to be safe. And if the stain doesn’t come off, gently rubbing with a damp microfiber cloth might help – but no scratching, or it will just make things worse.
Sometimes it also helps to let the furniture dry thoroughly after cleaning; then you can often see more clearly whether the stain is gone or just smudged.
jotisi
20 Oct 2021 09:45
Seanni schrieb:
Try lukewarm water with a few drops of lemon juice, that worked wonders for me
Well, I remain skeptical about whether lemon juice is really a good idea on high-gloss surfaces. Citric acid can damage the sealant, and with sensitive materials, this becomes noticeable quite quickly.
People often say that home remedies are harmless, but with high-gloss finishes, careless cleaning can easily cause dull spots or scratches. There is a difference between cleaning wood and lacquered furniture.
I would rather recommend using a plastic cleaner or furniture polish specifically designed for high-gloss surfaces. And very important: always test on an inconspicuous area before applying.
Gregory schrieb:
Isopropyl alcohol in low concentration is helpful, but test on inconspicuous spots first
I agree – such a product often brings clarity and is better than random home remedies.
