ᐅ Ikea Besta – How can I protect the side panels against moisture?
Created on: 9 Jan 2023 17:23
dalo55
dalo55
9 Jan 2023 17:23
I recently bought an Ikea Besta shelving unit and plan to use it mainly in the kitchen, where it may be exposed to occasional moisture. My question is specifically: what is the best way to protect or seal the side panels of the unit against moisture, so that neither water nor steam can damage them?
I want to avoid the wood swelling or warping over time. Since the panels are probably only glued or screwed on, I’m wondering if there are special protective coatings, films, or other materials that work particularly well.
Maybe someone has had similar experiences or can offer practical tips on which products or methods have proven effective to make the side surfaces more resistant to moisture, even when placed directly in the kitchen.
Thanks in advance for all the helpful replies!
PULAU
9 Jan 2023 18:02
To protect the side panels of Besta against moisture, I primarily recommend applying a high-quality, water-repellent varnish, preferably polyurethane-based. These varnishes create a durable, flexible protective layer that also repels vapor.
Before applying the varnish, lightly sand the surface to improve adhesion. It is also essential to ensure that the panels have no damaged edges, as moisture can easily penetrate there. The edges can be further treated with special edge sealants.
Alternatively, applying thin, self-adhesive PVC films that are waterproof is possible, but careful, bubble-free application is crucial.
Another measure is to avoid placing the furniture directly in damp areas and, if necessary, ensure adequate ventilation.
These are essentially the most practical methods.
Keatondra
9 Jan 2023 18:45
Hello dalo55,
Your question is very good and addresses a common issue with kitchen and bathroom furniture: the moisture resistance of wood-based panels.
Basically, you should know that the side panels of Ikea Besta are often made of coated particleboard – so moisture protection is applied at the factory, but it is limited.
If you want to improve the moisture resistance, you can consider the following:
- Seal the visible edges with waterproof acrylic or edge paint specifically designed for wood-based panels.
- Additionally, paint the sides with a moisture-repellent clear coat (e.g., marine varnish or polyurethane varnish).
- Make sure the furniture does not stand directly on damp floors – use raised feet or adjustable legs if necessary.
- Avoid standing water or constant exposure to steam on the panels.
I hope these tips help you. A note to keep in mind: depending on the usage, a combination of these measures may be advisable.
brianna
9 Jan 2023 19:10
Keatondra schrieb:
Your question is very good and relates to a common issue with kitchen and bathroom furniture: the moisture resistance of wood-based materials.
I agree. I once had the problem that my bathroom shelves swelled due to the steam, which was really frustrating.
So I would definitely recommend making sure the protection on the sides is not just for looks but truly waterproof. To me, this means applying several layers of varnish and, especially, carefully sealing the edges.
A good tip from me: when applying varnish with a roller or brush, sand lightly with fine sandpaper between coats and then apply another layer. This makes the protective layer more durable and watertight.
Especially with Besta, where the side panels are not actually a moisture barrier by themselves, this method can significantly delay damage.
Gafiel
10 Jan 2023 08:32
To address the topic in more detail:
Ikea Besta side panels are usually made of particleboard with a melamine or foil coating, which is not fully moisture-resistant—especially the edges are vulnerable. This means the protective approach should consist of several components:
- Edge sealing: I recommend using a waterproof acrylic sealant to protect the edges. Alternatively, there are special edge lacquers that can be applied with a fine brush.
- Surface sealing: If the side panels are not already melamine-coated, or if the coating appears worn, a clear lacquer based on polyurethane should be applied in at least two coats.
- Preparation: Before application, all surfaces must be sanded thoroughly (grit 180–220) to ensure good adhesion of the lacquer or sealant.
- Additional measure: If you plan to use the shelves in damp areas, such as next to sinks, maintain a minimum distance or install small cover strips as splash protection.
I am curious about the exact condition of your Besta panels. Are they melamine-coated or foil-coated? And what is the humidity level in the room (kitchen with steam exposure or occasional moisture)?
This information helps to determine the appropriate measure.
dalo55
10 Jan 2023 09:11
Gafiel schrieb:
I’m interested in how exactly the Besta panels are currently made in your case? Melamine coating or foil? And what is the humidity level in the room (kitchen with steam exposure or occasional moisture)?
Good question! As far as I can tell, the panels are melamine coated. The surface feels rather smooth and firm, not like typical foil.
The kitchen is used regularly, but it isn’t subjected to heavy steam exposure like, for example, near a stove. The shelf is placed on a wall right next to the sink – so water splashes there occasionally.
Humidity is usually normal, except it becomes somewhat higher during cooking, but not extremely so.
My main concern is to make the area around the side panel and edges water-resistant over the long term, without having to fully recoat the entire piece of furniture.
