ᐅ Ikea BESTA – How do I build a combination of open and closed units?
Created on: 10 Feb 2021 14:07
balazs69
Hello everyone, I am planning a custom furniture project using the Ikea Besta system and would like to create a combination of open and closed elements. My idea is to build a shelving unit that includes open compartments for decoration or frequently used items, as well as closed cabinet doors for hidden storage. I have a few questions, especially regarding practical installation, material compatibility for the doors, and the optimal arrangement of the modules. It would be great if someone could share their experience on the best approach to build a stable and visually pleasing combination. What tips are there concerning fasteners, load-bearing capacity, and design options with different fronts? Thanks in advance!
julian36
10 Feb 2021 16:42
For installation, I recommend the following sequence: First, assemble the individual modules completely, including the back panels on the closed elements. Then connect the modules to each other using the connecting elements. It is important to tighten all of these securely and evenly to avoid twisting or misalignment. The doors should only be installed after the modules have been fixed in place, as installing them earlier makes adjustment more difficult. For better stability at the module edges, optional metal brackets can be added inside if needed.
Seanni
10 Feb 2021 17:05
Sounds like an exciting project! From my experience with Besta, the combination of open and closed elements is actually great for design. A tip: if you want to make the open compartments a bit more dynamic, you could install individual shelves at different heights. This not only looks stylish but also uses the storage space more efficiently. I also chose doors with soft-close hinges – it adds a touch of luxury!
balazs69
11 Feb 2021 09:23
One more question regarding the design: Is it possible to mix different fronts (e.g., wood and painted doors) within the same shelving combination without any fitting issues? Are there any system-related limitations concerning the doors and their mounting, or can they be combined freely? The usable depth is the same for all modules, so it only concerns the front design.
FLOBAU
11 Feb 2021 10:01
The use of different front materials with BESTA is generally possible. The fronts are designed independently from the carcasses, and the mounting system is modular. However, it should be noted that varying material thicknesses and weights of doors can affect the adjustment of the hinges. Additionally, it is advisable to carefully plan the color or material transitions visually, as the depth and edge profiles of wood-effect fronts may appear different compared to smooth lacquered fronts.
keogla
11 Feb 2021 11:18
You can combine fronts, yes. Just be careful with the hinges, as there are different models depending on the door thickness. If you use different materials, check whether the hinges are compatible. And always make sure to adjust them properly so they close well.
Ritaba
11 Feb 2021 11:55
Especially with doors made from different materials, the adjustment of the hinges may vary. Simply follow the installation instructions and then adjust the door accordingly; it will fit properly.
