ᐅ Ikea BESTA – How do I build a combination of open and closed units?
Created on: 10 Feb 2021 14:07
balazs69
Hello everyone, I am planning a custom furniture project using the Ikea Besta system and would like to create a combination of open and closed elements. My idea is to build a shelving unit that includes open compartments for decoration or frequently used items, as well as closed cabinet doors for hidden storage. I have a few questions, especially regarding practical installation, material compatibility for the doors, and the optimal arrangement of the modules. It would be great if someone could share their experience on the best approach to build a stable and visually pleasing combination. What tips are there concerning fasteners, load-bearing capacity, and design options with different fronts? Thanks in advance!
balazs69
11 Feb 2021 12:40
Thank you, that helps a lot. One last question: What installation method do you recommend for a combination of open and closed units? Is it better to secure the shelving to the wall, or are the modules with floor mounting stable enough to avoid wall installation altogether? Unfortunately, my apartment doesn’t have any consistently load-bearing walls, so a floor-mounted solution would be of interest.
julian36
11 Feb 2021 13:12
Wall mounting is recommended for Besta units, mainly for safety reasons, but the base cabinets are quite stable on their own. You can improve floor fixing using small brackets or by adhering the cabinet to the floor. If the combination isn’t too tall or too low, the stability is usually sufficient. However, be cautious with children or restless pets – wall mounting is definitely safer in those cases.
Seanni
11 Feb 2021 13:43
It is also possible to achieve stability without wall mounting by using proper support feet and, if necessary, connection brackets at the bottom. However, as julian36 points out, safety comes first. For non-load-bearing walls, it is better to rely on floor fixing or additional stabilizers.
V
Victor54
11 Feb 2021 15:08
I believe the issue of wall mounting should not be underestimated. Especially with tall or narrow modules and mixed elements, there is a risk of tipping. Even if it is technically possible to create a stable combination standing only on the floor, there remains a residual risk that should be consciously accepted. Safety comes before design.
balazs69
12 Feb 2021 09:51
Great, thanks for all the tips and suggestions! The advice regarding installation, material compatibility, and stability is very helpful for preparing my BESTA project properly. I will follow the tips on adjusting, combining the doors, and securing the modules. If I have any questions during assembly, I will gladly reach out again.
