ᐅ How can I childproof Ikea BESTA doors without complicated installation?
Created on: 15 Oct 2016 08:17
Sepega
I’m looking for an effective way to childproof the doors of my IKEA Besta cabinet without complicated or time-consuming installation. Ideally, I want a solution that is easy to attach and just as easy to remove when needed. It’s important that the doors stay securely locked to prevent small children from getting access, but I don’t want to undertake major modifications or lengthy installations.
Does anyone have practical tips or experience with child safety locks specifically for IKEA Besta doors? Which methods work well, and which ones are better to avoid? Thanks in advance for your ideas!
Brian schrieb:
I would also pay attention to the durability of the locks.That’s an important point, but I wonder if it’s realistic to expect truly residue-free solutions when installing most child safety locks. Even adhesive pads usually leave marks, especially on painted surfaces.
Moreover, the question arises of how long such a lock really remains childproof—children often develop surprising skills to bypass them.
Perhaps it would be worth considering whether it makes more sense to make the furniture itself safe, for example by using fittings with integrated locks or drawers with soft-close mechanisms, rather than relying on temporary adhesive solutions.
To complement the previous contributions: The simplest yet effective solution is often a tension lock that can be installed between the trim and the door without any tools.
Advantages:
- No drilling or adhesives required
- Quick to install and remove
- Child-safe, provided the lock is difficult to release from the outside
This works well with Besta because the doors have some tolerance. A tension lock reliably prevents the door from opening.
I recommend measuring the dimensions carefully before purchasing, as door thickness and gap width are critical.
Advantages:
I just thought of a really simple solution: How about using rubber bands or straps with Velcro fasteners?
You can easily stretch them loosely across two doors, and just like that – childproof! If you need to get in quickly, just unfasten them for a moment.
Of course, it’s not the most aesthetically pleasing option, but for everyday use it’s really convenient and easy. And no child can really remove such a strap unnoticed.
Just a little idea for an uncomplicated life 😎
Thank you very much for the diverse feedback so far!
The idea of toggle clamps sounds interesting, and I will definitely take a closer look at the clip and magnetic locks as well. I especially appreciate the tips about residue from adhesives and materials – I really want to avoid that since I don’t want to alter the appearance of the BESTA doors.
A quick question for everyone using clip or toggle locks: How durable are these in everyday use? Do they remain stable with frequent use, and is the door still easy for adults to open without much effort?
I don’t want to be constantly frustrated when I just want to quickly grab something from the cabinet, but of course, the children should be effectively kept out.
Sepega schrieb:
A quick question for everyone using clamp or tension fasteners: How durable are they in everyday use?In my experience, tension fasteners have proven to be very reliable. Even with daily use, they remain stable and do not come undone by themselves.
They function well for adults, as the opening resistance is not too high, but the mechanism is harder for children to open. One drawback is that tension fasteners can show slight signs of wear over time depending on the material, although this rarely occurs with normal use.
My advice: When buying, pay attention to quality materials to ensure the best durability.
Sepega schrieb:
I don’t want to keep getting annoyed every time I quickly want to grab something from the cupboard, but of course, the kids should be effectively kept out.That is a very reasonable request. Personally, I have had good experiences with products that can be opened and closed with one hand but are difficult for children to operate.
In addition to latch fasteners, I also recommend paying attention to the two-point locking principle: if only one point is secured, children can often easily pry it open. Two locking points on the sides are much harder for small hands to overcome.
The installation should be simple as well – for example, by hooking on or using adhesive – to keep the effort required for assembly low.
