ᐅ Ikea BESTA: How can I improve the drawer slides?
Created on: 2 Jun 2022 09:12
nesar
I recently installed several IKEA Besta drawers in my living room and would like to improve the drawer slides, as I feel they sometimes operate a bit stiffly and do not always close precisely. My question to you is: What options are there to enhance the function and smoothness of the Besta drawer slides without resorting to extensive modifications or expensive replacement parts? I am interested in both simple maintenance measures and technical tips that can be easily carried out by oneself. What experiences have you had with lubricants, drawer runners, or possible modifications that work particularly well with the Besta series?
nesar
3 Jun 2022 08:55
BOLUKEO schrieb:
If the drawer is difficult to open, it could also be improperly installed or the drawer slides may be bent.
That’s interesting, as I was very careful during installation, but maybe a slight bend has developed through use. What is the best way to check this without fully removing the drawer?
letar
3 Jun 2022 09:27
nesar schrieb:
How can I best check this without completely removing the drawer?
Carefully pull the drawer out halfway and then inspect the runners both visually and by feeling them with your hand. Pay special attention to any bends, waves, or uneven gaps. The drawer should also slide smoothly without requiring much force. Any wobbling or catching usually indicates bent runners. A deliberate test to see if one side moves more than the other can also provide useful information.
fiman
3 Jun 2022 10:02
Always lubricate with silicone spray, as it does not attract dirt. If the rail is bent, you can carefully straighten it using pliers. Be cautious and work little by little.
LOJOPAR
3 Jun 2022 10:45
I would also recommend checking the screws on the tracks and the drawer box. Loose or over-tightened screws can cause the tracks to twist or come loose. This often has a noticeable impact on the smoothness of operation. So, when you get the chance, also inspect the mounting points. To be on the safe side, you can use small plastic washers as a base to better distribute the pressure.
JORDON
3 Jun 2022 11:12
nesar schrieb:
What options are there to improve the function and smooth operation of the BESTA drawer slides without resorting to complex modifications or expensive replacement parts?
Hey, first of all, respect for the good and detailed question! ? I’ve also taken a close look at my Besta cabinets and found that it often helps to fully unload the drawers—that is, avoid keeping anything inside that causes unnecessary pressure. The slides are designed to handle specific loads.
Once the drawer runs smoothly and lightly, I do a quick check using silicone oil and a bit of patience. And honestly, occasional fine-tuning and tightening screws never hurt.
Good luck with your project! And if you like, let us know how it went.
