ᐅ IKEA Besta DIY: How to Build a Combination with Different Drawer Sizes?
Created on: 15 Oct 2021 09:13
MAERGIN70
MAERGIN70
15 Oct 2021 09:13
Hello everyone, I am currently planning a DIY project using the Ikea Besta system, but I want to create different drawer sizes within a single frame. My main question is: How can a combination of various drawer widths and heights be implemented effectively and stably within the standard modules? I intend to arrange about two smaller drawers and one larger drawer stacked vertically to accommodate different storage needs. At the same time, I am interested in how to handle the assembly or partitions in such a setup so that everything holds well and remains functional without compromising the overall stability. Does anyone have practical experience or tips regarding the appropriate fittings, compartment layouts, and possible modifications to the Besta frame? Thank you in advance!
NUPIN
15 Oct 2021 10:47
Hey, very interesting topic! I have personally built a Besta combination with drawer modules of different heights, and it wasn’t that difficult :-) The key is to use the internal panels of the frame smartly. You can use the shelf supports to create different levels and then adjust the drawer units flexibly. Pro tip: Stability improves if you align the drawer fronts precisely and use the appropriate metal slides from Ikea (e.g., Maximera). This way, everything moves smoothly and looks great! Just take it step by step and enjoy the process!
Danabla
15 Oct 2021 11:23
Regarding the question about combining different drawer sizes in the Besta system: The module is basically flexible, as the shelves and side panels can be positioned variably. The most common drawer widths are 30 cm (12 inches) and 60 cm (24 inches). For a stable installation, all cross panels should be securely fixed, especially when combining different heights. The MAXIMERA drawers can easily be ordered in different heights, allowing for customized positioning close to the floor and spacing between drawers. Careful planning of the mounting screws and the use of clamps during assembly are important to prevent deformation.
ryan1
15 Oct 2021 12:12
NUPIN schrieb:
I have already built a Besta combo with drawers of different heights myself, and it wasn’t that difficult at all :-)
I can only confirm that! I recently fitted my living room with a similar setup, and it fits perfectly! The MAXIMERA drawer slides are really worth it because they work with different drawer sizes and run very smoothly 😃. It’s important to plan the layout carefully in advance and note down the measurements precisely – then it will definitely work!
GUMARTINA
15 Oct 2021 14:57
The Besta system is modular, allowing you to easily combine drawers of different sizes. Use shelves as dividers and MAXIMERA rails for the drawers. Ensure secure installation and precise measurements.
Leonardteo
16 Oct 2021 08:34
From a technical perspective, when combining different drawer sizes, it is important to consider the load capacity of the shelves and choose the appropriate drawer fronts. Ideally, the fronts should be selected to enhance the stability of the structure by providing additional support surfaces. Additionally, when dealing with varying heights and widths, the correct mounting hardware must be used to prevent stress on the frame. The Besta system offers flexible solutions that can be implemented with careful planning and without major modifications to the frame.
