ᐅ How can I customize IKEA Besta furniture to fit sloped ceilings?
Created on: 15 Nov 2022 18:27
petoneo
petoneo
15 Nov 2022 18:27
Hello everyone, I am facing the challenge of custom-fitting IKEA Besta furniture under a sloped ceiling. My main concern is how to adjust or combine the modules so they fit the angled wall perfectly, without large gaps or compromising stability. Are there any proven methods, special cuts, or clever tricks to optimize Besta cabinets for sloped ceilings? I am especially interested in how to work with IKEA’s standardized dimensions and whether it’s worthwhile to create additional custom wood panels. I look forward to your experiences and tips – including recommendations for tools and assembly techniques that have proven effective.
Jorgela
15 Nov 2022 19:03
First, it’s best to accurately measure the height under the sloped ceiling at several points and then create a sketch. You can cut the upper shelves so that they follow the slope. Additional fillers or battens as supports often help to fill the slope.
KNUTGI
15 Nov 2022 20:45
This is definitely an exciting project! If you want to customize the modules nicely, my advice is: Be bold with custom cuts – Besta is standardized, but with a bit of creativity, you can fill the angled space really cleverly. And hey, a bit of precision work often makes it feel truly homely! A bit of sandpaper, a jigsaw, and a steady hand are your best friends for this 😉.
sarlo
16 Nov 2022 08:12
Hello petoneo, it’s great that you are already familiar with the technical terms and describe the situation clearly. My recommendation is to use the Besta carcasses as the basic framework and to cover the upper sloped roof area with custom-cut MDF panels or laminated wood. It is important to measure very precisely beforehand and, if necessary, create a template. Using angle brackets or connectors is also recommended to ensure the structure remains stable. If appearance is important to you, you can paint the visible surfaces to match the Besta color tone. Tools: jigsaw, cordless screwdriver, miter box. Feel free to ask more questions.
Garry
16 Nov 2022 10:28
One important point that is often overlooked: avoid fitting the back panels of the cabinets flush against the sloped ceiling. Instead, leave a small gap for air circulation to help prevent moisture damage. Additionally, I recommend securing the modules with sturdy brackets both to the wall and, if necessary, to the roof slope. For cutting the shelves, using a router is worthwhile to achieve especially clean edges.
NOAHSAU
16 Nov 2022 13:47
petoneo schrieb:
how to adjust or combine the modules so they fit the sloped wall perfectly, without creating large gaps or compromising stability.
Isn’t that basically a lost cause? IKEA designs Besta specifically for flat walls, and any custom modifications take time and money. If you want the best possible fit, forget IKEA and look for furniture made by a professional carpenter. “Custom-made” with IKEA is often tricky and a compromise.
